3d space navigator will not work in 2017
I'm having issues with my 3d mouse not rotating or doing anything at all really.  I have the 3d connexion space navigator.  It works fine in the 2016 version, but not 2017.
Hi, go to 3d connexion website to update your drivers.
The latest release is from october: http://www.3dconnexion.com/service/drivers.html
The compatibility for 3ds Max 2017 has been add in the May release:
2.5 Release of May 6, 2016
- Update 3DxWare 10 to version 10.4.3.
- New: Add support for version 2017 of Autodesk 3ds Max.
- New: Add support for “Custom Views” commands in add-in solution for Autodesk 3ds Max and Maya.
- Note: Stability and performance improvements to driver software.
Alfred.DeFlaminis
Hello @Anonymous,
Did the suggestion by @Anonymous work for you?  I just wanted to make sure.
Best Regards,
This worked! Thank you.
Alfred.DeFlaminis
Hello @Anonymous,
Thank you for the update, this will help other users with a similar issue.  Kudos to @Anonymous for being on top of this.
Best Regards,
