3D max error
3D max error
Good evening, everyone. There was a fairly frequent error (I Hope that it is frequent) in 3D max.
I have a 64-bit version of 3D max 2018.
Up to a certain point, I used a non-licensed version of 3D max. After recent problems, the same problem has occurred again, although I have installed the student version (Yes, I am a graduate student).
The problem is an error in the program for 3 files, namely:
3dsmax_minidump.dmp
dmpuserinfo.xml
dumpdata.zip
Opening one of the documents found that the error is in the absence of a certain file ( in my case, the problem was that there was no folder.).
I reinstalled 3D max 6 times at least, deleting all the data completely. Then I discovered a strange thing.
In the error caption, 3D max indicated that I have the 3D max version 20, although I have version 18.
If someone has this error, help us understand, and then we have a Russian-language audience that understands little and does not give an answer.
irishman_team_kilber
that is a crash dump, the only way to read the files is if you have the MS debug tool and it's symbols to read what they say if you open them in another notepad for example you cannot read them, but yo need to know what you're looking at,
if you attach the file then someone can help you,the only time i get that error is by using the 3ds max AEC extended windows and doors if I copy them across max will crash. and through up that error
fill it that crash reporting error and submit it to autodesk with what you were doing and make sure you fill out the email address once you make that then send it, autodesk will give you a ref number and letters if you post that here then an autodesk can look up that ref number and he/she will give you an answer or a work around.  i would not post your email here because you will get a lot of unwanted emails.
I checked the dmpuserinfo data again. The error is made using the following path:
C:\Program Files (x86)\Common Files\Autodesk Shared\AppManager\R1\CER\upiconfig.xml
If you try to follow exactly this path, you will not be able to find the final file. upinconfig.xml located in my other folders "Autodesk Shared". Folder "R1" I do not have at all.
I would have posted a screenshot of the full error, but I don't know exactly what information is better to leave on the screen.
the screen shot only tell you to submit it to autodesk and that is what i told you to do and then once sumitted you will be given a reference  numbers with letters  and you post that here so an autodesk empoyee can look it up, as i am not empolyee of autodesk i cannot help you anymore
arq.josedavidpabon
Community Visitor
Community Visitor
Hola a mi me salio el mismo error pero con la version 2022, al fin se pudo solucionarlo de alguna manera ?
joaquim.moral
¡Hola @Anonymous!
Gracias por tu participación en los foros de Autodesk.
Te animo a que si participas en los foros en inglés, incluyas una traducción al inglés en tus respuestas, con tal de que las personas que participan en esa comunidad entiendan tus aportaciones.
Por otro lado, te animo también a que participes en la Comunidad en Español, de la cual yo soy el coordinador, y te esperaremos con los brazos abiertos!
Aquí tienes el link de la Comunidad en Español: https://forums.autodesk.com/t5/espanol/ct-p/157
¡Hasta pronto y gracias por tu participación!
Hello @Anonymous !
Thank you for your participation in the Autodesk forums.
I encourage you if you participate in the forums in English, that you include an English translation in your answers, as long as the people who participate in that community understand your contributions.
On the other hand, I also encourage you to participate in the Community in Spanish, of which I am the coordinator, and we will wait for you with open arms!
Here you have the link of the Community in Spanish: https://forums.autodesk.com/t5/espanol/ct-p/157
See you soon and thanks for your participation!
Translation by Google Translate
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
Community Visitor
Community Visitor
Hello did you fix that ?lm facing the same problem😭
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
