3d max crashes on opening material editor
This widget could not be displayed.
when ever i try to make material or try to open material material editor . my 3d max crashes... even if i open new blank file and try to open material editor . it crashes
Replies (17)
5vil
You can try reset to default setting of 3ds Max. 1st step turn off Max if still running. Then go to:
%username%\AppData\Local\Autodesk\3dsMax\2020 - 64bit\ENU
Rename the "ENU" folder to another name. Open Max again and check if the error got solved or not?
(Doing so will reset your custom toolbar button (for scripts,...), custom UI, etc... You can export/save them before doing the steps if necessary).
still facing the same issue
5vil
Have you use any multi-monitor software (such as AWM, ...)
https://www.actualtools.com/forum/read.php?FID=10&TID=3939
Does the crash have same error msg or situation like this one (?):
https://forums.autodesk.com/t5/3ds-max-forum/material-editor-load-up-issues/td-p/8769327
Did it only crash with VRay render engine or all available one, did you tried switch (back and forth) to another renderers (Scanline/MentalRay/Arnold/etc...) before open Mat Editor (ME) again? Do you happen to have massive amount of cores/threads on your PC? (there was a issue with too many cores back then in scanline renderer). Did you try to switch to another viewport display modes (Direct3D, Nitrous, OpenGL, etc...) and open ME again?
This one is old, but did you see anything similar to your problem in it?
https://forums.autodesk.com/t5/3ds-max-forum/max-2014-crashing-issue-upon-opening-material-editor/td...
i have tried all these solutions..but the error is only with vray render..... i cant switch to any other because as soon as i apply material,, default render automatically changes to vray..
i even had a live chat and they told me about clean install and that browser download... i followed there instruction.. i downloaded the setup again but the setup is showing error that files are missing
jon.bell
Hello @Anonymous,
I just wanted to check back here to see if you were still having these issues with 3ds Max and V-Ray, or if the problem was resolved.
Could you please let us know?
Thanks for your time, and we hope to hear from you soon!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
jon.bell
@Anonymous ,
Just wanted to refresh this thread to see if you were still having these issues, or if they were fixed at this point. Can you please let us know? (And if Chaos Group gave you a solution, I'd be interested in seeing it here as well.) Thanks!
Jon A. Bell
roland8217
Community Visitor
Community Visitor
I also am having this issue; spontaneously.Tried reseting ribbon and a fresh re installation of 3dsmax.  Using vray next and 3dsmax 2014.
jon.bell
Hi @roland8217,
When 3ds Max crashes, is it allowing you to submit a customer error report (CER) with your email address? If so, can you please send me a private message telling me the address your using, or if the CER numbers that you're seeing after submitting the defect reports? Thanks!
Jon A. Bell
jon.bell
@roland8217 ,
Just checking in to see if you were still having this issue. Also, since 3ds Max 2014 is quite old and is no longer being supported, I wanted to see if you had upgraded to a later version and if this issue was still happening for you. Could you please let us know? Thanks!
Jon A. Bell
jon.bell
Hi @Anonymous , @roland8217 and @5vil ,
Just wanted to revive this thread one last time to note the following possible fix from another customer. Could you please let us know if these steps work for you?
Hi, thanks for your post, i had tracked the string in config file. hope it will be helpful. In file:
C:\Users\...\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU\en-US\defaults\MAX.vray\CurrentDefaults.ini
find:
[100 C80 0]
; V-Ray Material
materialType=0x37bf3f2f 0x7034695c
change materialType:
from
to
materialType=0x3d6b1cec 0xdeadc001
(taken from default max config.ini)
Works for me in 3ds Max 2021.1 with Vray 5.00.04
Jon A. Bell
What can I do if I use corona
nipunhp
Observer
Observer
If you are using Corona, Reinstall corona will fix it,
atrodler9ELLJ
Community Visitor
Community Visitor
I use arnold!
experiencing same crash problem. First thing I did was update to latest arnold release.
Any ideas?
CiroCardoso3v
If you switch to Scanline, do you still have the same issue?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
kelanidavid3
Community Visitor
Community Visitor
I use max 2021 with vray 6, I don't have the MAX.vray folder, instead I have MAX but after checking the .ini file I couldn't find the line for
[100 C80 0]
; V-Ray Material
Please what can I do?
mn_nishaf23
Community Visitor
Community Visitor
Same problem for me. have you find the solution?
binishbutt19
Community Visitor
Community Visitor
yes it is.... Whenever I open the material editor even with blank page it shows the msg and crashes. Give me some solution how can I resolve this issue
