Updated to .2 and now I can not load a scene. The CPU pegs at almost 100% usage and it freezes opening it. I can merge some objects, but not all of them. There wasn't anything special about those objects. Uninstalled and reinstalled max 2023.1 and everything works as expected. Please allow for a dot release uninstaller if they're going to fail this spectacularly.
No bueno.
Hi @Grace.Tevlin,
Hopefully someone with more experience may chime in.
Here are some things that always help speed up troubleshooting:
Many thanks.
Regards.
Thanks for your response. Unfortunately nothing so far.
We have couple of projects that XForm is used a lot and this issue caused serious problems in our Marketing productions. We have already switched back to Max 2022.
This issue came from the first Max 2023 release. It was reported to Autodesk support without any solutions.
It has been tested on few machines and all the same.
Tested on a fresh Max 2023, also another one with VRay plugin installed.
A sample project with a video is attached.
Thanks again for your help.
Just bumping this, to see if there has been a solution since the last post?
Thanks 🙂
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Hi everybody, I am using 3ds max 2024 and experiencing this problem too. I use chamfer modifier a lot, the project is unable to finilize loading at 69%.
