3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
2014 Surface modifier normal bug
13 REPLIES 13
Message 1 of 14
simonparish
1110 Views, 13 Replies
simonparish
Change of behaviour from 2012-3 to 2014.
When building spline cages to be used with Surface modifier the normals now seem to be random and inconsistent.
In pervious versions reversing the spline direction would flip the patch normal. In 2014 it is just random.
When opening a correct normal surface (all facing one consistant direction) made in 2012 and modified in 2013, into 2014 all the normals are flipped at random.  Reversing the spline corrects some patches but flip a different set of other patches, making fixing the surface a massive random trial n error process.  Adding one new spline can completely break a good surface.
It can be fixed by added a Normal modify onto the surface but this causes a MASSIVE delay when trying to modified the spline cage.
Can anyone confirm this as a 2014 bug?  Is it still apparent in 2015?
Simon
I need a new signature
Max2017.1 | Vray 3.70.01| win11
ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070ti
Simon
Tags (3)
13 REPLIES 13
Message 2 of 14
jonathan.matthews
Hello and thank you for your posting.  Please take the time to post this information at the following Autodesk link:
Bug Submission
This is a direct link to our development team.
After posting you should recieve a tracking or submission number.  Please let me know what that is so I can keep an eye on it.
Thank you.
Bug Submission
Thank you.
Message 3 of 14
simonparish
Hi Jonathan,
thanks for the interest, if you want to know more here is the case number.
Case 09578384 - 2014 Surface modifier normal bug
Simon
Simon
Hi Jonathan,
Simon
Simon
Message 4 of 14
paulneale
in reply to: simonparish
paulneale
I didn't even know any one was still using the old surface tools. Good to see that it is still useful to some one. Thanks for posting the bug report.
Paul Neale
http://paulneale.com
Paul Neale
Paul Neale
Paul Neale
Message 5 of 14
simonparish
in reply to: paulneale
simonparish
Ha Ha, it probably is a bit antiquated Smiley LOL but can be more flexible that a polymesh when doing R&D and the model is changing a lot or has slight variations in form.
Also one of the first bits of software I learnt was Hash Inc's Animation Master which was a patch modeller, then moved onto Alias PowerAnimator which had beautiful NURBS tools, only wish AD would finally get around to updating Max's NURBS with some of the great code that they own.
Until then spline cages will feature heavily in my workflow.
Smiley Surprised and it's still around...
http://www.hash.com/index.php?pcode=software_details
Simon
Simon
Message 6 of 14
Steve_Curley
Steve_Curley
Tip. HTML tags - Confucious not [i]Confucious[/i] 😉
You wouldn't have a small (non-copyrighted, ofc) example of this problem you could post here would you? Would be interesting to see if the same error shows up with a 2012 scene in 2015 too, either directly or having gone through 2013 as well.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Max 2016 (SP1/EXT1)
Message 7 of 14
simonparish
in reply to: Steve_Curley
simonparish
Hi Steve,
Sure thing, this is the file I sent to AD on the bug report. (with most of the customer detail removed)
The orignal cage was probadly built in 2011 and has had yearly amends and changes using the different Max version.  All worked ok in 2013 when there was a great speed improvement as I think some optimisation work must have been done as it used to get real slow with a heavy complex cage and surface.
2014 broke the old models that had worked fine.  A work around, as I think I said was to add a Normal modifier, but that I think that creates and even worst bug in the spline editor, as it sends Max into world of treacle.
Anyway have a play.  You may get a prize if you can tweak the cage to get all the normals to work. It is possible. Smiley Frustrated
Simon
Hi Steve,
Simon
Message 8 of 14
paulneale
paulneale
You might want to try jumping on the poly band wagon as the shapes that you have there are easy and fast to build as you don't have to do it one vert at a time as you do with splines. To each his own though, beauty of Max, 10 ways to do everything. Don't hold your breath for NURBS.
Paul Neale
Paul Neale
Paul Neale
Paul Neale
Message 9 of 14
Steve_Curley
Steve_Curley
Thanks for posting that. I see the same as you in 2014, in 2015 however it is perfect, but completely inside out. Simply hitting Flip on the Surface Parameters cures that. No "tweaking" required.
Definitely a 2014 issue - loading the scene in 2015 and saving back (what appears to be a perfectly ok scene) to 2012/13/14 then opening those scenes in their respective versions are all ok, except for 2014.
Quite what the chances are of getting that fixed now (as 2015 has been released) I don't know. Worth a try, I suppose.
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 10 of 14
simonparish
simonparish
Now that is great to know.  Might be the reason I install 2015, but I normally wait a bit longer... Although SP1 is now out.
#Paul you know what they say about old dogs Cat Wink
Thanks guys
Simon
Thanks guys
Simon
Message 11 of 14
Steve_Curley
Steve_Curley
Try it as a trial on a spare machine - just so you can check that full scenes are ok. There are a few issues with 2015 though most are not serious enough to cause real problems.
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 12 of 14
simonparish
simonparish
Just wanted to say s thanks for the 2015 tip, I have it installed and can confirm that the normal big is gone and wow, it is now FAST, FAST, FAST.
I may have to take off my hat off and eat me shoes, AD seem to have done a good job!!Smiley Very Happy
I even like the new layer manager, quad menu is a bit flakey but...anyway I digress.
Thanks again guys for your input.
Simon
Simon
Message 13 of 14
paulneale
paulneale
Make sure that you keep the service packs up to date in all your software as they correct the issues as they are found. I would say 90% of the issue that I see other people having is because they are still on the first install of any given version and have not updated.
Paul Neale
Paul Neale
Paul Neale
Paul Neale
Message 14 of 14
jonsteinberg
the best link to bookmark for the 3ds Max bug reporting form is:
http://www.autodesk.com/3dsmax-bugreport
this will always dynamically redirect to the correct form.
