I have an airplane and a propeller. Both are animated. I want to work on the prop. Is there any way to freeze the airplane animation while animating the prop? I suppose I could link the plane with a camera and apply a constraint so that the camera viewport makes the prop appear to be animated independently, but is there a way to freeze one of the animations?
Hi.
If you need to have the airplane object static and visible, I'd recommend using a Snapshot tool. This will create a static copy without the animation.
1. Select airplane and go to Tools menu and choose Snapshot. Choose Range and enter frame where youd lie to create your copy.
2. Select your original and Hide Selected.
You can do few things if you simply want to hide objects:
a) Select the Plane object and right-click, Hide Selected. Also available in Display Tab in Command Panel.
b) Select the Propeller object and go to Tools Menu and choose Isolate Selection or Alt + Q. Also available via right-click MB.
I think I misunderstood the question. Steve's suggestion is much better. 🙂 Sorry you didn't get a response.
