Light Rotation & Camera Placement Issues
In 3ds Max 2019 -
1) My ability to rotate free lights with Ray Traced Shadows with a Uniform Distribution (rectangle). I've done nothing different in my scene set-up. It's a problem even on previously used scenes. I can move the lights using the Move Tool, but I can't rotate them in any direction. All I get is the angle in the color of the chosen direction with no movement of the light (see attached pic).
2) When I add a Physical Camera by using the "Control C" combination from a set scene, the camera now faces down instead of capturing the scene/aligning to the view I have set-up. The hotkey works (tried and checked Interface Hotkey list), but the camera is vertical.
(NOTE: My experience and education with Max is very non-linear, so please make the answer as easy to understand as possible.)
Did I hit a wrong button I didn't realize? Any ideas?
Dave
miledrizk
For the light rotation go to Hierarchy, Link Info tab, and make sure
All checkboxes under Locks are unchecked as in the image below:
For the camera creation: after setting the scene, and before clicking the Ctrl+C
Make sure your mouse is inside the desired viewport, then use the combination
Ctrl+C
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
infoVCXQB
it is best answer, I was going to point for him. thank for showing
Happy animated days.
Cheers
Kibrit Creative Solutions  l Cloud Render Farm
Cloud Render Farm: https://www.kibrit.com.tr/rental-gpu-render-farm/
