Circle pattern on metallic material
dpsd1989
dpsd1989
I am facing a problem in my render scene. I am trying to render a facade and circle patterns appear on the material. I change more than 5 times the material. I added and deleted the UVW map. I deleted the Sun light Vray.
Can anyone help me to fix it please cause I do not know what to do?Capture.JPG
Francisco_Penaloza
First be sure you are using a licensed copy or 3D Max and V_Ray.
That model was done in Sketchup? or in 3D Max?
it may be a backward-facing plane or an overlapping geometry.
Also, turn off any displacement you may have and test your scene.
Are you using V Ray dirt on your material? turn that off and see if that fix it.
