3ds Max Design Visualization Workflows
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max design visualization topics.
Missing textures when object is imported
1 REPLY 1
sburkeW2VGV
920 Views, 1 Reply
Hi people! So basically, i have been purchasing a lot of objects from CgTrader, Turbosquid etc. I download the objects in Corona format, since i use corona render. The object in corona format, and the textures/maps are downloaded and unzipped into a library. I give the file a test run, just to see if the textures and scale is in place. They are, but once i import the files into my interior scene file, they are missing. This happens almost everytime, and it completely destroys my work flow. anybody else had this problem before?
1 REPLY 1
Yea it happens because you may not use a relative path in your Max project.
I do the same but I use a script called 'Relink bitmap' just point to the folder where all those textures are and this script put everything back to normal.
