3ds Max Color Management
Welcome to the Autodesk 3ds Max Forums. Share your knowledge, ask questions, and explore 3ds Max color management topics.
Parameter editor
1 REPLY 1
sagynzhan03
235 Views, 1 Reply
Parameter editor
When I load HDRI, the output section is not completely visible in the editor parameter
and it doesn't change at all
it looks like it's been cut off
Labels (1)
1 REPLY 1
mbreidt
in reply to: sagynzhan03
Looks like a bug in Corona bitmap to me - what Windows UI scale do you use? And what is your screen resolution? Which version of 3ds Max?
Could you try this without any  UI scaling, just to see whether this avoids the problem?
Another thing you could try is to detach the parameter panel by dragging it off at the two horizontal dashed lines at the top - does that make any difference?
