For example, I made it basic flag but there is a problem that is I can't figure out the loop. I tried everthing but there must be a logical way. Please help me.
Solved by leeminardi. Go to Solution.
Could you provide a bit more information about what you are trying to do and what you have tried but didn't work?
I made it flag with rectangle and garment maker. I arranged the wind and simulated the flag, so everything is okay until so far but the problem is how can I make a looping animation flag. I tried to some tutorials where you can found in this forum but it's not coming to me clearly. I can't figure out. Everyone mentioned about to do point cache> morpher> but these are not understandable. Can you explain?
Does this help?
If the action is not seamless enough try copying the first set of keys (Shift drag when dope sheet id fully expanded) from the beginning to the end before doing the looping steps described in the link above. If it is still to choppy between loops copy the second set of keys to near the last set.
