05:41 AM
Hi to everybody, I'm a new 3DSMAX user.
I'm trying to make a simple animation with 3 cubes. Cube A si the "master" cube with static dimensions and is in the central position. Cube "B" and "C" are "slave" before and after the "A" cube. I would like to stretch them if cube "A" moves... leaving the start point of the Cube B and Final point of Cube C fixed.
Please take a look at the image attached. As you can see the first "row" is the initial state, then in the second row A moves to left, in the third row A moves to right. My animation needs to have B and C stretching to adapt to A movement. Is there any way to achieve this ?
Thanks in advance for your suggestions.
