3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
Some help with Orientation (thread / path constrain) small detail about Autodesk Learning Video
2 REPLIES 2
bioclone_ax45
315 Views, 2 Replies
bioclone_ax45
Hello, Im having a bit of trouble with this:
The video itself used is this one: https://www.youtube.com/watch?v=MlKjJxtaTjU&
I have no problem with the video at all, but does not cover my problem by the way the threads are modeled for the tutorial.
Image reference
As can be seen, on certain parts the threads follow the correct orientation, but on other places they get inverted... while a cheap way would be simply to have them simetrical on both sides I would want to avoid that, someone can provide me a reasonable way to keep them looking outside?
Image reference
2 REPLIES 2
domo.spaji
in reply to: bioclone_ax45
domo.spaji
Check "Allow upside down" in Path Constr.
bioclone_ax45
in reply to: domo.spaji
bioclone_ax45
I am trying to find the option using the info here
https://help.autodesk.com/view/3DSMAX/2023/ENU/?guid=GUID-FC720C8E-0015-4D86-AC09-AD122EDC7929
but honestly I dont get where it is 😛
UPDATE
NVM was able to found it ( I dont get how I looked on the same place like a docen times and now I realized where it was finally...)
It also seems to work nicely, I need to perform some more test but well, I really expected it to be harder many thx!
UPDATE
