Snaping pivot problem in animation
b_degroote
b_degroote
Hello, i have a problem with a pivot in a group ( sometimes with other parts too )
I transfered the pivot from the middle of this group to the bottom. If i now want to rotate the object around the new pivot it snaps back to the old pivot. What i am doing wrong? Sometimes it works, sometimes not.
leeminardi
After moving the pivot try clicking Reset: transform int the Adjust Pivot panel.
lee.minardi
MartinBeh
I recommend to avoid groups in 3ds Max. Especially when animating.
Instead I recommend to create a helper object, place it where you want the pivot and then parent your current group members to it (after ungrouping).
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
b_degroote
Thank you very much! That helped a lot! I am using now the linked helper objects, much better than grouping objects.
MartinBeh
Glad this worked for you. Feel free to click the 'Accept Solution' button...
anuj_abhiwan
If you're having pivot snapping issues in animation in 3ds Max:
  • Don’t move the pivot directly during animation—use dummy objects or helper nodes to control pivot movement.
  • Use "Affect Pivot Only" in the Hierarchy panel before setting keyframes.
  • For snapping, enable "Use Pivot Point Center" in the toolbar and check Snap Settings (S) for correct snap options.
