Announcements
skin modifier grow button problem
Hi, Im having a pretty weird problem with the skin modifier. When I select a ring and then I want to pick also the aside rings I always use grow, but in this case, Max is selecting the double of the selection, I mean, is like I hit twice the button grow but Im only pressing it once!. Also, the shrink reduce the selection twice. This is very anoying, I couldn't find anything about it so I guess Im the only one with this problem or there's an option in Max 2016 that does that, in that case, I usually use 3dsmax 2015 but Im using 2016 because of the improved tools for skinning.
Hope you can help me to solve this. Thanks!
Dont know why, but I did an xform to the mesh and it is working now properly, I thought that it was something related exclusively to the 3dsmax version. Thanks!
Fersuarez24
Community Visitor
Community Visitor
Hi!!! in my case the issue is when I have a reference mesh. I "make unique" my model and the issue is solved.
jesped
SEVEN YEARS later, this is still happening in 3ds Max 2024...   🤦🏻
That's how much Autodesk cares about fixing bugs.
