Save and Load Animation Keeps generating a Key Per Frame even tho it's unticked
liamw6PYEF
liamw6PYEF
Hi
I'm having an issue with Animation->Load animation and Save animation.
I've tried multiple ways of saving and loading animation and each time it creates "Keys per Frame" Even tho its not selected i'm my settings?  I'm sure in past versions i could just save and load my keys with having them converted to baked / key per frame.
I would be grateful for any help.
Here are the settings i've used below
save settingssave settingsmapping settingsmapping settings
load settingsload settings
Seems that you have to map the individual tracks instead of the transform.
liamw6PYEF
Thank you aon.914858227 for you helps
It just seem strange to me that you need to do that. I've copied and pasted transform controller to objects in the scene and that fine.
Agreed, it seems odd. Can you test this with an older versions of 3dsmax? I only have 2019.1.1 installed.
liamw6PYEF
I tested it in 2018 and max 2016 and they both create key per frame
AutodeskUser1235
im on 2022...
just saving and loading anim off and onto the same rig. so mapping was automatic / not required.
was getting these stupid baked keys...
i determined it was due to not having a key on every track. without one itll bake keys. with a single key on every track it gave the exporter/importer animation to save. for whatever dumbass reason, max decides there should be keys on every frame if you save out anim when theres no anim on its track. sure! lets put anim where there was no anim!
elijahmason918
Community Visitor
Community Visitor
If the "Save and Load Animation" feature is generating a key per frame despite being unticked, it could indicate a potential issue or bug.
In such cases, it's recommended to double-check the software or application settings to ensure that the "Save and Load Animation" option is indeed turned off. Sometimes, user interfaces can be confusing, and it's possible that the option may not have been disabled properly.
If the issue persists even after verifying the settings, it may be worth reaching out to the software's support team or consulting relevant forums or communities for assistance. They can provide insights, troubleshooting steps, or possible workarounds to address the problem.
Remember, software behavior can vary, and occasional glitches or unexpected behaviors may occur. Reporting the issue to the appropriate channels can contribute to improving the software and ensuring a smoother user experience for others facing similar difficulties.
Click Here to read more articles.
