"Warning: Non-Orthogonal Matrix Support" message appears when exporting CAT rig from 3ds Max
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi! I have a problem with the "Warning: Non-Orthogonal Matrix Support" message appearing when exporting a CAT rig from 3ds Max to .fbx. I understand that this is because I have CAT Bones that have been non-uniformly scaled. I have googled the crap out of this and come across many possible solutions that didn't help me, but the most helpful has been https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Warnin... . From that support page I have downloaded the script Fix_CAT_BoneScale.ms and have used it as directed and have managed to successfully reduce the number of non-uniformly scaled bones down from ten bones to only four. But four bones are still giving me errors - two neck bones, one spine bone and the head bone. I have tried, as step 6 in the support document suggests, to run the script on each bone within the rig from the highest bone within the hierarchy, but it still doesn't fix those four bones. Strangely, the spine bone and the head both actually have scales of 100, 100, 100 but are throwing up errors anyway. As for the two neck bones, they do have non-uniform scales such as 100, 99.996, 100.004, and if I try to manually enter a scale of 100, it just jumps back to the previous value. Screenshots and max file are attached.
