PFlow - Trigger animation
GeoffKornfeld
GeoffKornfeld
I am using PFlow to populate a surface with instances of an object. That object has an animation on it, but I only want that animation to start on the Shape Instances when they come in contact with another object or Deflector. Is this doable? Thanks.
Yes, that`s possible. Simply put in the second event that is triggered by collision a second Shape Instance(same object) and turn on 'Animated Shape' only there. That should trigger the animation if collision happens.
Sample scene:
