Object deviation from Path Constraint
Hello!
I am still pretty green on rigging / animating. It seems like my dummy object with patch constraint is following the trajectory and not the exact path. I have the weight set to 100%. How do I have the dummy object follow the exact path?
I recreated the dummy and did a path constraint but it still yielded the same results. The image below shows the dummy selected that is off the path.
Thanks in advance!
Issue Resolved: Bezier corner was making the dummy shift off of the line. Thanks!
