1. Go to the 'Command Panel' and then to the 'Helpers' tab. Create a 'Point' helper in your scene and place it at the exact spot you had intended for your object to rotate from.
2. Animate the helper to do your 360.
3. Select your object (rock) and go to the 'Hierarchy' tab of 'Control Panel' and click 'Affect Pivot Only.'
4. Hit 'Shift+A' and click the Point helper. Your rock's pivot point should snap to it. Now click the 'Modify' tab of 'Control Panel' to get out of 'Hierarchy' and to set things.
5. Select your rock and go to the 'Select and Link' icon click it, and click and drag your rock so it links to the Point helper. The helper will blink once when you let go to let you know it linked.
If you scroll the timeline, your Point pivot should now rotate your rock along with it. What's good about this is that now if you want to change how the rock rotates, you can leave the Point helper and just move the rock and change things easily.
If you animated the Point helper properly and it's rotation like you want, then the rock should follow nicely. If not, just manually move the rock until you like the way it follows the helper.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
