Keyframes on curve editor dissapeared
Message 1 of 14
I was edit my vray camera (path constraint on camera and target edited by the autokey) when I open my curve editor to clean up keys I can't see my keyframes, only dotted line like that
http://images77.fotosik.pl/373/383c6a6c0e89bdec.png - screenshoot,
when I create simply box and keyframe position from point to point and open curve editor, there was the same situation, but when I open a new project everything on curve editor worked just fine, I don't know whats going on, can anybody help me please?
Replies (13)
Message 2 of 14
kgokhangurbuz
Hi;
Go to Curve Editor > Show > Show Non-Selected Curves. You can now select and adjust your keys / curves.
Best regards;
Message 3 of 14
thanks for this tip but unfortunately when I select this one, nothing changes... I still can't see keyframes, and only dotted line is there...
Message 4 of 14
kgokhangurbuz
Hello;
I'm sorry that i've missed something. You mention that your Camera is constrainted to a path; but you are trying to clear the keys of the target of your camera? (in your screenshot not the camera but its target is selected).
Message 5 of 14
Exactly 🙂 my camera is constrained to a path, but target was animated on autokey, now I want to clean it pup. But the point is, I just for try created on the same scene simply box, and animated position and in this case I got the same problem on the curve editor...
Message 6 of 14
kgokhangurbuz
Can you please save your file for 3ds Max 2014 and share with me so i can take a quick look?
Message 7 of 14
sure 🙂 how I can do it? I'm new here
Message 8 of 14
kgokhangurbuz
Below your reply box where you type you reply, there's a section called Attachments, Choose file and simply upload via that option if it's under 10 MB's 🙂
Message 9 of 14
ok, take a look please 🙂
Message 10 of 14
kgokhangurbuz
I think you've not saved your scene for 3ds max 2014, can you re-upload as 2014 please?
Message 11 of 14
Message 12 of 14
kgokhangurbuz
I've received and opened your file,
I cannot seem to figure what the problem is but i will be examining the scene. Even if i create a box and animate, i cant see the keys in Curve Editor.
Lets wait for another replies while i dig into the depths of this scene of yours.
Talk to you soon 🙂
Message 13 of 14
kgokhangurbuz
I think you better go with the Mini-Curve editor meanwhile, this appearantly is a bug somehow, it does not react to anything, but again, if someone comes up with an exact answer, i'll be glad to hear it too.
To reach Mini-Curve Editor:
I'm able to see and modify every key from this section, so you should be too.
Best regards;
Message 14 of 14
ok, mini curve editor works for me very well 🙂 thanks 🙂
