Hello.
Is it possible to have an objects position animated between 2 points and for max to keyframe every frame of the animtion for me?
Cheers
Solved by paulneale. Go to Solution.
Motion Panel / Trajectories and then Collapse the transform for position, set the start and end times and samples as needed.
Thank you this works a treat. It was nice to see it actually works on an objects whose movement is created by multiple position constraints also.
Cheers fella!!!
