It's a pretty simple situation here.
I'm in 3DS Max and I'm using the HI IK Solver for the legs of my character. Most characters I have works perfectly with the IK Solver when I move their "Hip" bone up and down, their knees bend like they're supposed to.
But, a couple of character models I have do not work as well and they're no different then the working models. When I move the Hip bone up and down, their knees either bend sideways or a just a bit sideways. The models are also T-Posed and their legs are as straight as they can be.
(Also, I'll need a little help with arms and wrists as well. I use the Limb Solver for them, the issue is that the elbow bone doesn't rotate the right way when I move the wrist bone. The shoulder bone is the starting point with the elbow bone being in the middle.)
Solved by ads_royje. Go to Solution.
Hi @derek.mallard ,
when creating a bone chain for an Ik Solver, they should not be strait. There should always be a little angle, so the solver 'knows' how to bend.
If you remove the Ik solver and give the bone a little angle, then recreate the Ik solver. This little angle will tell the solver what side you expect the solver to bend.
For the second question, about the arm setup, I am not sure I see what you are describing, could you do a screenshot of your setup, something that displays the problem ?
Hahaha, okay. Such a big fuss and a very small simple solution to fix it with. Thanks again!
And also, since you told me the solution about the bones needing to be bent, I think I can apply it to the next issue.
Thanks for the screenshot @derek.mallard ! 🙂
Yes, from that I am with you, looks to be related.
Let us know if you encounter any other issues!
