How Can I Animate to Visibility on Object's Modifier?
semih.topcu
semih.topcu
Hi. I am trying to animate Slice Modifier on 3Ds Max 2021. I want to object's slice modifieri can be visible in frame 0, then cannot visible in frame 10. But when I look to dope sheet, I can't add visibilty track to modifiers. It can be possible any way? You can see what I mean at attached picture .
leeminardi
Select the object (ICBA_BR...) not the modifier to enable the ability to add a visibility track.
Note that some renderers, e.g., Arnold, do not support the visibility track.  In that case use a cutout map that transitions from  black through gray to white to effect visibility.
Another option, depending on your requirements, is to use a ProBoolean subtract as  done here.
lee.minardi
semih.topcu
Thanks for your answer. But when I tried to add visibility track on ICBA_BR... its all visible -or not- all object. I want to add visibility track only slice modifier. Is this possible?
leeminardi
How about keyframing the position of the slice such that it doesn't slice the object when you don't want a slice?  Use a step function for these transitions.
lee.minardi
semih.topcu
Thanks I can use this. But Slice modifier's plane uses high performance. I have performance issues with this solution.
CAMedeck
You could always have a clone of your object that does not have a Slice modifier, and animate that version to become visible when the other becomes invisible.  So it appears that the Slice has disappeared, when in fact the object with the slice has disappeared and an unsliced version has appeared in its place.
Chris Medeck
