Help with animating only certain portion of an object
- Mute
- Permalink
- Report
Hi all. In the image below, I am animating a jet bridge. The portion outlined in red rotates in the direction of the red arrow. However, as you can see, there is a wire attached to the pillar and the jet bridge. I want to pin the wire's movement at the blue crosshair specifically as it rotates with the rest of the bridge, but I also want the wire to deform as it rotates along that pillar. The object in question will only rotate 180 degrees, and not 360 degrees. How can this be achieved
