Can anyone help me with this issue. I want to combine more animation like jump, walk , run... all this in one mixamo rigg. Is this possible?
Solved by ads_royje. Go to Solution.
Hi there,
You may want to look at Motion Mixer tool (Max main menu > Graph Editor > Motion Mixer).
Motion Mixer is a animation tool that can do that.
For each of your Animation files, you can export from Max as a .xaf file (Max main menu > Animation > Save Animation)
This will create a .xaf file.
Using a scene that has your Mixamo rig, open Motion Mixer, add your rig as a Max object and then you can load the .xaf files as animation clips.
More information on using Motion Mixer here :
And Max documentation here :
http://help.autodesk.com/view/3DSMAX/2016/ENU/?guid=GUID-A4F4A6A6-27A9-482C-9A95-853B1ADC68C4
Hope that can help! 🙂
hello,
For some reason i cant combine multipe animations on my rigg. I need this for a prezentation if you are more experienced can you help me please? i will send my little project if you want:D it's a panda bear, and i want to make 5 different moves, in one single rigg. thank's
Hi!
I cannot do the work for you (nothing's learned that way), but I can show you how to use it.
Attached you'll find a video showing step-by-step how to use the motion mixer using a custom rig (a non-biped rig) from an fbx file.
Steps are :
. save animations as .xaf files
. open the rig in the scene
. from Max main menu > Graph Editors > Motion Mixer
. add rig to motion mixer as Max objects
. add .xaf animation files as clips
In the attached video, you'll have a step-by-step how to get to use them in Motion mixer.
Hope that can help you get there! 🙂
Thank you so much for the mini tutorial. now i understand how to use motion mixer. one small problem, the tab to create the map dosen't appear when i load the xaf file. I've made all the steps like you said. I will try again to see if i do something wrong. Thank you again for everything
Happy that it can help! 🙂
I forgot to mention, but you may have noticed that already, when 'saving animation' to .xaf files, you need to have selected the rig. The Save Animation to .xaf file saves selected objects animations.
The mapping table can look complex, it is, as it can allow quite advanced mappings.
General rule, mapping transform to transform is good for most cases. In some advanced usage of the Mixer, one could map rotation y to position x etc ... or have various source clips for rotation and position...
Once you get the hang of it, motion mixer can do lots of cool stuff!
Have fun! 🙂
Hi again, 🙂
I have one more question, i have 5 different riggs with different animation, downloaded from mixamo. to combine all i need to save in xaf file and make mapping for all? and then i will import my idle rigg or t-pose...and start combine all my animation? is that correct?
Great news! 🙂
Thank you for the update!
Have a great day too!
