CAT elbow fixing 3Ds max
p.eminov
p.eminov
Hi! I would like to fix or target elbow control of my CAT character, my character leaned on balcony, so when I move his pelvis control, the elbows are moving, but I want to target elbows to balcony wood. Help me please!
martin.coven
Hi  p.eminov
Select the arm and in the Limb Animation rollout, create a IKTarget. Once you have a target, set the arm to use IK with the IK/FK slider. Now you can set the num IK Bones to 1, and place the IK target at the elbow.
The Num IK Bones can also be animated, so if you need to go back to driving the arm with full IK, you can do that.
Best,
Martin
Martin Coven
Senior Designer
p.eminov
Thank you my brother, this answer is the solution of my problem!
