Book rig - using a page's orientation value to drive a bend value?
PaalGustavWiderberg9222
Hi all.
I'm pretty novice at rigging, but I've tried my hand at a book rig.
Each page has a LookAt Constraint pointing to a helper and the helpers spread out, as the book fold out.
Now what I'd like to do is to have a bend modifier on each page, and to have the Angle value driven by the page's gimbal x value - When the books is closed the gimbal x value is 0 - also driving the bend modifier angle value to 0. When the book is unfolded the outer pages will have gimbal x value closer to 90, the bend value would say, 75.
Is there a simple way to set this up?
Using 3ds max 2019
I think I might have figured it out - using a ExposeTM helper I can read out the values and use expression manager to link them to the bend value. Problem now is to set it up with some 150 pages...
leeminardi
Could you also make the page's bend amount and rotation value a function of the page's position?  For example, if the pages are stacked in the z direction then the bend and rotation value of the page could be a multiple of the page z coordinate.  Pages near the top of the book should bend and rotate more than pages near the bottom. If so, you may be able to array, clone (instance?) a single page rigged correctly to create the other pages.
lee.minardi
