Hi guys. I downloaded a character from the character generator and imported it into my scene. And run the script. I then hid the low res skin layer so I could just see the biepad skeleton and animated like this. When I turned the low res skin layer back on it was in exactly the same position I turned it off in. And it just stays there as the biepad moves on by. Is there a way I can attach the two so the low res skin layer moves with the biepad and works. And are merged as they should be. Thank you.
