.avi video file does not appear when imported
 I have a .avi file that I'm adding into a plane. I drag the file from the folder onto the bitmap slot in materials. Video does not appear onto the plane. I tried UV mapping it but that doesn't help. The plane turned black and doesn't play. When I try rendering it, the plane appears either white or grey.
ads_royje
Hi @Anonymous,
this may be due to the avi codec.
Avi format is a "container" and can be encoded via various codecs.
Max currently supports avi codec : uncompressed, DV video and MJPEG.
Same as the render output.
When selecting a video file from the Material editor Bitmap picker, if the file does not produce a thumbnail in the UI, the file is not readable by max.
Ideally you'd use a image sequence.
There is another thread on this forum about that, here :
https://forums.autodesk.com/t5/3ds-max-forum/mpeg-as-a-bitmap/td-p/6374303
Here is my own recipe.
There are many utilities out there to convert videos from a codec to another.
The one I usually use is called HandBrake, it is an open source freeware that can convert any format to an .mp4 format, using either the h.264, h.265, mpeg-2 and mpeg4 codecs.
What I end up doing is to use hand brake to convert using the "mpeg-4" codec and then I rename the extension from .mp4 to .mov to load in Max.
I hope this can help you ! 🙂
Thank you very much. I will try this out.
 Hello again,
Since I am an amateur animator, I was unsure how to convert & use a image sequence. However, I tried your tip of downloading HandBrake and it worked! Thank you again
ads_royje
Great to know !! 🙂
Thank you for your feedback!
