Mpeg as a bitmap
Mpeg as a bitmap
Logos_Atum
Advisor Advisor
Message 1 of 11
Mpeg as a bitmap
Logos_Atum
Hello there,
recently I attempted to recreate a scenario I managed to
get to work several years ago. Actually I did set up a virtual
cinema screen to enhance and clean a video file.
I am not sure about the colour format I used. The plain mpg2
( 2 4-2-0), looked promising, yet I think I might have to fall
back to mpg1.
If I remember right I used a Macross Plus clip captured with a
BT 484 and Macrovision software. Sadly the Haupauge (winTV)
disc is gone and mention of the software seems to have vani-
shed too.
Actually I don´t manage to remember at the moment.
Hint in regards of colourspace and resolution restrictions to
adhere to are very welcome.
Kind regards
Daniel
Dogs aren´t flammable.
Replies (10)
Message 2 of 11
Alfred.DeFlaminis
Hello @Logos_Atum,
Regarding using MPEG's as a bitmap, this should work in most setups though you are correct that the compression codec may have an impact on the ability to be loaded.  In my experience the best option is to convert the movie to frames so that when you scrub the timeline it's not trying to load the entire movie with each frame move.  If you export the frames out and load them into the RAM player, it will automatically create an .ifl (Image File List) that you can use as the target map and it will load the frames in as needed.
Regarding the rest of your post, all the codec differences are a bit beyond the standard scope for 3ds Max technical problems, but the color space if it's at gamma 2.2 should be pretty close to sRGB.  (If that helps.)
Best Regards,
Message 3 of 11
Logos_Atum
Hello Alfred,
thank you for the hint. I did something in the way.
As the avi file conversation to frames helped me to assign an image sequence as a source, the regular rgb colourspace worked just fine.
Gamme is a grey topic to me still.
Thank you for the *.ifl hint, I was wondering how to classify that.
1.8 should be a nice grey gamma.
Have a nice day, and I'll get back to you as soon as I tested it.
Currently on vacation...3 weeks for the first time in 5 years. Have not had more than 5 days in a row sice then.
Kind regards
Daniek
Message 4 of 11
spacefrog_
Daniek;
what Max version are you using ? Qinming Ren - former 3ds Max developer & viewport wizard - has created an absolutely astonishing FFMPEG reader plugin for 3ds Max 2015 up to 3ds Max 2017 and released it for free.
http://forums.cgsociety.org/showthread.php?f=6&t=1357562&highlight=ffmpeg
Using this plugin, you can literally play back any FFMPEG compatible video in REALTIME right in the viewport as viewport background or even as texture mapped onto some geometry. The sad part about this is, that Qinming was hit by the 10% workforce layoff round announced back in february and had to leave Autodesk, but that's a different story ....
I recorded a video about how good this plugin actually works back when it was released....
( And yes - those are two video streams playing right in the viewport in realtime )
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 5 of 11
Alfred.DeFlaminis
Hello @Logos_Atum,
I just wanted to follow up here, did this work out for you?  I'd love to mark one of the posts as a solution if it indeed did solve your problem, or offer further assistance if not.  Is there anything I can do?
Best Regards,
Message 6 of 11
Logos_Atum
Hello Spacefrog,
well it´s green.... and I´ll have a look. Currently I´m using the 2016 build of Max.
I´ll have a look at the plugin as soon as I manage to free some resources. FFMpeg
takes me back to DVD and 1999 in general.
Playing mpeg files back in the viewport, worked at some point- yet that´s been years
and it took me a week to consider conversion options prior.
I´ll get back to you as soon as I can.
Kind regards
Daniel
Message 7 of 11
Logos_Atum
Hello Alfred,
thank you very much, works exactly as you said. Given
realistic maps are enabled, timeline and frames for the
animation match too.
Thank you so much
Daniel
Message 8 of 11
lightcube
Just for INFO: SP2 for Max 2017 broke this plugin for me in 2017. So be aware of that.
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Message 9 of 11
Logos_Atum
Hello lightcube,
I have not yet downloaded the plugin yet, and
followed Alfreds instructions. Also I remembered I did do it in the same manner more than a decade ago.
A screen recording suite as a medium worked fine. I simply captured a region to frames. The avi's had been supplied already. Usually our video contractor supplies frames too. Recompressed lossy compressed bitmaps aren't desireable, I agree.
Is there a security concern too?
Message 10 of 11
Alfred.DeFlaminis
Hello @Logos_Atum,
I'm glad it worked out for you!  If you have any troubles or anything, please let me know and I'll be there asap.  Also, love the sig.  Smiley Very Happy
Best Regards,
Message 11 of 11
Logos_Atum
Hello Alfred,
I surely will.
Thanks so much
Daniel l
