Arnold - Object to become transparent during animation
cwymer
cwymer
Hi all ๐Ÿ™‚
I am using Arnold Renderer to animate fluid flow through a pipe. I want the pipe to appear opaque and then become transparent for a few seconds to see the fluid running through it. Then I want the pipe to become opaque again.
I have tried using the Object Properties options to change 'Visibility' settings but it does not render in Arnold ๐Ÿ˜ž
I have attached a image of what I mean.
Please can you recommend a method I can do this?
leeminardi
Arnold does not support the visibility track. You can use a cutout (opacity) map instead and animate it.
lee.minardi
cwymer
Hi Lee,
Thank you for your reply ๐Ÿ™‚
Under the Slate Material editor I cannot see the 'Cutout' Map. I did a search for it but no results ๐Ÿ˜ž see Attached image.
Where can I find this map?
Thank you !
leeminardi
Add a Physical Material that will be the material that fades away.
Connect an OSL:Color map to it.  You can find the map under OSL, Values
Keyframe its color from white (totally visible) to black (invisible).
See the comments at this thread and the file of @Anonymous  's post #4.
lee.minardi
cwymer
Thanks for your support Lee, works perfectly ๐Ÿ˜
leeminardi
I just became aware that to enable the visibility track when using Arnold you must assign the object an Arnold Properties modifier then enable Visibility under General Properties.  Once you do you can keyframe values for visibility as I do in this video.
You can use this method instead of the cutout map if you wish.
Lee
lee.minardi
