3ds Max Animation and Rigging
Welcome to Autodeskโ€™s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Arnold - Object to become transparent during animation
5 REPLIES 5
cwymer
1746 Views, 5 Replies
Hi all ๐Ÿ™‚
I am using Arnold Renderer to animate fluid flow through a pipe. I want the pipe to appear opaque and then become transparent for a few seconds to see the fluid running through it. Then I want the pipe to become opaque again.
I have tried using the Object Properties options to change 'Visibility' settings but it does not render in Arnold ๐Ÿ˜ž
I have attached a image of what I mean.
Please can you recommend a method I can do this?
Labels (4)
5 REPLIES 5
leeminardi
in reply to: cwymer
Arnold does not support the visibility track. You can use a cutout (opacity) map instead and animate it.
lee.minardi
cwymer
in reply to: leeminardi
Hi Lee,
Thank you for your reply ๐Ÿ™‚
Under the Slate Material editor I cannot see the 'Cutout' Map. I did a search for it but no results ๐Ÿ˜ž see Attached image.
Where can I find this map?
Thank you !
leeminardi
in reply to: cwymer
Add a Physical Material that will be the material that fades away.
Connect an OSL:Color map to it.  You can find the map under OSL, Values
Keyframe its color from white (totally visible) to black (invisible).
See the comments at this thread and the file of @Anonymous  's post #4.
lee.minardi
cwymer
Thanks for your support Lee, works perfectly ๐Ÿ˜
leeminardi
in reply to: cwymer
I just became aware that to enable the visibility track when using Arnold you must assign the object an Arnold Properties modifier then enable Visibility under General Properties.  Once you do you can keyframe values for visibility as I do in this video.
You can use this method instead of the cutout map if you wish.
Lee
lee.minardi
