animation issue in rotation - please help before I go to hospital
martinflash
martinflash
why rotation animation goes into issue in 3ds MAX?
is it the same in Blender?
here is my video with the issue
leeminardi
Can you post a 2025 compatible file containing the key components?
lee.minardi
MartinBeh
Not entirely sure but if I remember correctly, auto-key treats hierarchies somewhat different than what you see in the viewport.
Can you show the tracks your are animating in Trackview/Curve Editor? I guess there is some hierarchy of objects involved here?
PS: Does this also happen if you rotate less than 360 degrees?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
A娘
you should add a dummy on top of the controller to rotate , create a dummy , align to rotate controller , must align the position and rotation ,  link rotate controller to dummy , if there is parent original  , insert dummy between them , then you can rotate current controller arbitrary
RGhost77
It look like gimbal lock problem to me
Royal Ghost | veda3d.com
lauri_barnhart
Welcome to the community, @martinflash.
Hope you are well. Looks like you have received some advice on this thread. Did any of the information shared by MartinBeh , mediknocx303, A娘 or RGhost77 help clarify your question? If any of the posts provided information to help, please consider clicking on the 'Accept Solution' button on the post(s) that helped. If you still have questions and need additional assistance, please update here.
Best,
Lauri | Community Manager
