3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
3ds max 2023 biped motion panel missing the keyframe section
3 REPLIES 3
truckexpert
392 Views, 3 Replies
truckexpert
3ds max 2023
It once was there but now, after saving and rebooting, my biped motion panel is missing the TRACK SELECTION panel.
Also, the animation keys are missing.
This is a model downloaded and converted using Character Generator and the Autodesk Converter Script
Any ideas??
Thanks!
Peace,
Dave
System Information:
3DS Max 2023 and 2024
Microsoft Windows 11 Pro
Dell Precision 5820
Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s), 24 Logical Processor(s)
Display Adapter: NVIDIA RTX A4000
Adapter RAM (1,048,576) bytes
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.7 GB
Available Physical Memory 45.6 GB
Total Virtual Memory 81.7 GB
Available Virtual Memory 56.5 GB
Page File Space 18.0 GB
3ds max 2023
Any ideas??
Thanks!
Peace,
Dave
System Information:
Dell Precision 5820
3 REPLIES 3
RobH2
in reply to: truckexpert
RobH2
I'm sorry you've gotten no response on this. It's not in my skill set so I can't help but I did want to check in. I'm sure you've done some Googleing. Did you ever solve it? If you did, can you post your solution in case it helps someone else?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Rob Holmes
truckexpert
truckexpert
Hi RobH2,
Thanks for the reply. I found the answer. See below.
As you probably know, different versions of MAX have different menu/panel appearances. Some changes are painful. The SET KEY button for biped figures (motion panel) was relocated and looks different now. It once was a red circle. Here it is. Hope this helps.
Dave
Peace,
Dave
System Information:
Dell Precision 5820
Hi RobH2,
Dave
Peace,
Dave
System Information:
Dell Precision 5820
RobH2
RobH2
Thank you. It will help other. I appreciate it.
Rob Holmes
Rob Holmes
