- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I follow the forum quite often, though I have never posted before.
I am making my first walkthrough animation. I have already made an exterior one just to give it a try, but it was just my camera following a circle, and my building was in its center, so it was quite forward.
Before I proceed to any rendering, I have a problem with my frame rate I 'd like to ask some help with, should anyone would give the time to read this.
I can't make out how to give a steady movement to my camera (camera 13 on my attached max file). When the top viewport is current, it moves fine, as it should, but when I go to the camera viewport, it stucks at the begining, it goes a bit faster then, it stucks once again, and then it progresses well to the end. I am confused. It is probably limited knowledge of 3ds max animation, but could anyone please help? how can I maintain a steady playback speed?
thank you in advance for reading this.
