Could someone tell me how I fix this?
because my model is blacked out.
http://img853.imageshack.us/img853/1056/ll2l.jpg
Things I have already tried:
flipped normals
modify > normal
added lighiting
verify the directory of the textures for the model
still nothing has fixed it.
First of all, close Max and start a new file. Create a piece of geometry, teapot, etc. Does it look normal? If so, there is something going on in your other file. If not, it's a global Max setting or issue problem.
If the new geometry file is ok then go back to your problem file. Assign it a new generic texture. Does that fix it? If not, give more info about your file so we can help. Do you have any lights in it. What render engine are you using. Upload the file and we can see if it happens to us.
We need just a bit more info.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Ok,
Could you download the 3d model?
https://www.dropbox.com/s/3dznh6jlecsczvw/3dmodel.rar
Because maybe you can see something that I don't see.
But you do have vray?
I opened the file and it looks OK in the viewport. I do have VRay but my license is all of a sudden not working and I don't have time right now to fix that. But there is something wrong. It won't render properly.
Look at the photo I attached. It looks good in the viewport but the render only renders the inside of the mouth. I added some real lights, and it still does not render. I converted it to a Mesh and then flipped the normals. No luck.
I'll look at it a bit more in a little while but there is definately something wrong with the girl and clothing mesh. I added a box of my own and it functions normally. So, I has to be the girl mesh that is causing the problem.
Ok, I had something misconfigured. Unfortunately, the file does look OK in my viewport and it "does" render normally. I don't know your video adapter but does it have enough memory? It sounds like an adapter issue to me too. Are your drivers up to date? Do you have another figure model that is about the same weight that you can open in a new file and see if it is normal. If not, then it's the girl model. If a similar weight model is black too, then it has to be your video adapter.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Can't find what you're looking for? Ask the community or share your knowledge.
