Visual LISP, AutoLISP and General Customization
Urgent Help required : LISP for deleting last line of a MText
26 REPLIES 26
Message 1 of 27
1742 Views, 26 Replies
Good morning!! We are requiring a lisp to delete last line of any MText on a click. I have a one that deletes last word of an MText on a click but the issue is that I cannot make the last line to delete instead it deletes the last word. Can you please help me out. I am a regular java programmer and not so expertise in lisp. It will be of a good gesture if you please help me out as it is really required for a project in which last line of a MText can be deleted. I am here by stating the lsp for your reference.
Best Regards,
Bireshwar Mallick
/*Deletes the last word instead of the last line*/
(defun c:33 ( / ss)
  (if (setq ss (ssget "_:L" '((0 . "MTEXT"))))
    ((lambda (i / e ed s)
       (while (setq e (ssname ss (setq i (1+ i))))
         (setq ed (entget e))
         (setq s (assoc 1 ed))
         (setq ed (subst (cons 1 (substr (cdr s) 1 (1- (strlen (cdr s))))) s ed))
         (entmod ed)))
      -1)
    (prompt "\n** Nothing selected ** "))
  (princ))
26 REPLIES 26
Message 21 of 27
Lee_Mac
in reply to: hmsilva
@hmsilva wrote:
Nice modification! Smiley Happy
Thank you Henrique!
For this task it would be useful if vl-string-search had the from-end-p flag that vl-string-position offers, e.g. something like:
;; vl-string-search with 'from-end-p' flag  -  Lee Mac
(defun vl-string-search2 ( pat str pos end / len rtn tmp )
    (if (and (setq rtn (vl-string-search pat str pos)) end)
        (progn
            (setq len (strlen pat))
            (while (setq tmp (vl-string-search pat str pos))
                (setq pos (+ tmp len))
            (- pos len)
        rtn
_$ (vl-string-search2 "\\P" "Line1\\PLine2\\PLine3" nil t)
12
Message 22 of 27
hmsilva
in reply to: Lee_Mac
@Lee_Mac wrote:
Thank you Henrique!
(defun vl-string-search2 ( pat str pos end / len rtn )
        (progn
            (- pos len)
        rtn
12
Nice one! Lee
Stored it in my toolbox... Smiley Wink
Henrique
Message 23 of 27
Lee_Mac
@hmsilva wrote:
Nice one! Lee
Thanks Henrique Smiley Happy
A minor update to my earlier post as I forgot to localise the 'tmp' variable Smiley Wink
Message 24 of 27
hi,
I am not sure who I have sent this to but I was hoping that _Tharwat might be able to tell me what I would have to change in his routine for the deletion of MText lines to allow me to remove the FIRST line and not the last line as in the lisp routine he provided for Bireshware. Could you please send back reply be email below
I tried the routine supplied and it works fine for the last line
Kevin brennan
food service design
kevinb@fsdaustralia.com
Message 25 of 27
_Tharwat
kevinb wrote:
hi,
Kevin brennan
food service design
Hello Kevin
Try this modified program and let me know how you get on with it .
(defun c:Test (/ s in en st _st r i)
  ;; 	--=={ Tharwat 30.1.2015 }==--	;;
  (if (setq s (ssget "_:L" '((0 . "MTEXT"))))
    (repeat (setq in (sslength s))
      (setq en (entget (ssname s (setq in (1- in))))
            st (cdr (assoc 1 en))
            r  t
      (while (and r (setq i (vl-string-search "\\P" st)))
        (setq r   nil
              _st (substr st (+ i 3))
      (if _st
        (entmod
          (subst
            (cons 1 _st)
            (assoc 1 en)
            en
  (princ)
Message 26 of 27
in reply to: _Tharwat
Thank you for the reply
The routine works a treat but could I ask if there is a way to keep the first line but with no text in it. We have a routine for incremental numbering that requires an open line to place the prefix and subsequent incremental number in. Your modified routine takes the whole line out and our routine adds the incremental to the front of the top line. I have attached a jpg file showing the grip points of the text before and after running your routine. On the left the FREEZER note on the top is the original already incremented text we need to alter. The text below shows the top line deleted after running your routine. On the right the top text is the existing and the text below is what we require to re-run our routine in - top line still available but with no text
Thanks anyway as if there is no way of changing t the above we will still use yours as it saves on having to select the text and delete it. We can easily add a space into the mtext to re-obtain the space line if we have to , so agin thanks
Kevin Brennan
Message 27 of 27
_Tharwat
Try this .
  ;; 	--=={ Tharwat 02.02.2015 }==--	;;
  (if (setq s (ssget "_:L" '((0 . "MTEXT") (1 . "*\\P*"))))
            r  t
        (setq r   nil
      (if _st
        (entmod
          (subst
            (cons 1 (strcat "\\P" _st))
            (assoc 1 en)
            en
  (princ)
”Boost
