An excelllent routine! Thank you very much (indeed to everyone) for your advice and assistance.
Regards
Duncan
If you double click the routine file and open with notepad and scroll down, there is a a section called 'how to use'.
Cheers
Duncan
ksmith84.
It is not mine , see the LISP head .
;;;; StripMtext Version 5.0b for AutoCAD 2000 and above
;;;; Removes embedded Mtext formatting
;;;; Copyright© Steve Doman and Joe Burke 2010
;;;; The authors grant permission to use, copy, and modify this routine
;;;; for personal use only and for the use of other AutoCAD users within
;;;; your organization. Selling, modifying, or exchanging this software
;;;; for a fee, or incorporation within a commercial software product, is
;;;; expressly prohibited. All other rights are reserved by the authors.
;;;; Please send comments, wish lists, or bug reports to:
;;;; cadabyss@gmail.com or lowercase@hawaii.rr.com
;;;; Look for new stable releases at:
;;;; http://cadabyss.wordpress.com/
;;;; More information may also be found at:
;;;; http://www.theswamp.org/
;;;; Subforum: "Show your stuff", Subject: "StripMtext v5"
This is a great LISP. And the very imformative narrative provided in the .lsp was much appreciated.
Hello
I have a version 5.0D ! But not tested on "modern" ACAD ! So please let us know ??
THE HEALTH (Stay Safe, Stay Live, Stay Home), Bye, Patrice (The Retired Old French EE Froggy)
Patrice BRAUD
@braudpat wrote:
Hello
There is a note in the perex about 2021 in french. Thx for the latest version.
Hello @ВeekeeCZ
YES on ACAD 2021, the solution is maybe LISPSYS = 0 !?
It was a remark of Gilles (gile) ...
THE HEALTH, Bye, Patrice
Patrice BRAUD
Hiya,
Glad it's of help mate but it was a better man than me who put it together so credit goes to that fella.
Cheers
Hi Guys!
So i have a bunch of Mtext boxes with a colour, which i want them to be "By Layer".
I never used an external command before. I loaded the command through appload and it is there. i prompt it. I say i want to remove format of colour. But nothing happens.. what am i missing in order to be able to chanhe ALL Mtext boxes to "By Layer" instead of a colour that is assigned to all of them?
Rui
ya probé esta Rutina y no funciona en mi caso, Xq???
Removí los colores, pero sigo sin poder cambiar las propiedades de forma MASIVA que es lo que necesito
I wrote the original version in 100% plain AutoLisp (between 2003 and 2005) before the team of Joe Burke and Steve Doman switched to using Regular Expressions. I'm sure that my old version will remove color override formatting from all the mtexts you select, if you want it. I called it UNFORMAT. It's really not very big.
John F. Uhden
@john.uhden , Hi John, if you open the lisp at post 2 , it mention about your collaborations as follow
;;;; v3.0 05-26-2003 "The Uhden Unformat Version" Vlisp
;;;; Powered by the new Unformat parser function written by John Uhden,
;;;; which provided much better, faster, and more reliable format
;;;; removing than previous versions. Added support for dimensions
;;;; objects and introduced a new DCL allowing users to choose individual
;;;; formats and save defaults. sd
So it is the one you mention.
