Visual LISP, AutoLISP and General Customization
show alert if not true
10 REPLIES 10
Message 1 of 11
288 Views, 10 Replies
I have a statment below which I can't get to work. Basically revision
letters need to be A then B then C then D etc If the revision letters are
not in this order then I want to show awarning.
In other words:
If RevLettOld equals "A" and RevLettNew equals "B"
or RevLettOld equals "B" and RevLettNew equals "C"
or RevLettOld equals "C" and RevLettNew equals "D"
and so on right through the alphabet
then proceed
however if for example RevLettOld equals "A" and RevLettNew equals C or D or
E or F G etc
and so then show alert box with warning message.
I guess I could make the statement :
if RevLettOld equals "A" and RevLettNew equals "C" or "D" or "E" or "F"
or "G" or "H" etc
and
if RevLettOld equals "B" and RevLettNew equals "D" or "E" or "F" or "G" or
"H" etc
etc etc etc
then show alert box
But I think this is a little cumbersome. Surely there must be a better way
to write the above expression
here is my attempt, but I can't seem to get it right
(if
(not
(and
(= RevLettOld "A")
(= RevLettNew "B")
);and
(or
(and
(= RevLettOld "B")
(= RevLettNew "C")
);and
);or
(or
(and
(= RevLettOld "C")
(= RevLettNew "D")
);and
);or
);not
(progn
(alert (strcat"\nRe-check rev letter and try again.... "
);strcat
);alert
);progn
);if
thanks Russ
10 REPLIES 10
Message 2 of 11
Hi Russ,
Doubtful I understand what you are trying to do. But I wonder if you could just
check to see if a list is in ascending order?
(setq lst '("A" "B" "C" "D"))
(if (not (equal lst (vl-sort lst '<)))
(princ "alert")
(princ "OK")
Joe Burke
"Kiwi Russ" wrote in message
news:0FB67C05AAD4AAE3A48774FAC7B618EC@in.WebX.maYIadrTaRb...
> In other words:
> then proceed
> E or F G etc
> or "G" or "H" etc
> and
> "H" etc
> etc etc etc
> then show alert box
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 3 of 11
Hi Joe
I have an attributed title block and one of the tags is the
revision letter. I'm trying to compare the old revision letter with the new
revision letter. If "A" is not followed by a "B" or "B" is NOT followed by a
"C" etc then I want to show a warning so that the user must type in a "B" if
the existing rev is a "A" and so on.
I hope that makes sense
cheers
Russ
Message 4 of 11
Russ,
Let's try this to see if I understand. Assume you know the old/existing revision
letter is "A". You prompt the user for a new revision letter to replace "A",
which must be "B", otherwise alert. The function needs to deal with whatever the
old revision letter was. If it was "R", the user must enter "S". You can't use
initget and getkword because those don't work with getstring.
Am I on the right track? If not, it's not your fault. I seem to have my
thick-head on this evening.
If the above is correct, maybe the ascii function as follows.
(setq existing (ascii "A")) ;example - returns integer
(setq new (< prompt for new revision letter >))
(if (not (= (1+ existing) (ascii new)))
(princ "alert")
Totally untested, Russ.
Joe Burke
news:4A541CC7F0B23A5A16DA052E059F198C@in.WebX.maYIadrTaRb...
> Hi Joe
> cheers
> Russ
Message 5 of 11
Strings comply with greater than (> ...) & less than (< .... )
AutoLISP functions.
(< "A" "B")
T
-David
> In other words:
> then proceed
> E or F G etc
> or "G" or "H" etc
> and
> "H" etc
> etc etc etc
> then show alert box
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 6 of 11
How about just deriving a valid revision from the old rev?
;;; A function to "increment" a letter
;;; The argument is a string (usually one character long)
;;; Returns a string containing the letter after the first letter of
;;; the argument string, except I, O and Q are skipped.
(defun incr_ltr (string / tempstr)
(setq tempstr (chr (1+ (ascii string))))
(if (or (= tempstr "O") (= tempstr "I") (= tempstr "Q"))
(setq tempstr (chr (1+ (ascii tempstr))))
(eval tempstr)
;;; BUMPREV increments the string passed to it, either a letter or a
;;; number
(defun bumprev (oldrev / rev_chars last_char)
;; Check for zero-length string
(if (= (strlen oldrev) 0)
(setq oldrev "0")
;; Check for validity of the string (last character
;; must be a letter or numeral)
(if
(or
(wcmatch
(setq
last_char (strcase (substr oldrev
(setq rev_chars (strlen oldrev))
1
(wcmatch last_char "#")
;; If it's an alphabetic revision ...
(if (>= last_char
"A"
;; increment the letter
(if (= last_char "Z")
;; Got to Z, need to increment first character (this
;; won't work right after rev ZZ)
(if (> rev_chars 1)
;; It's already a two letter revision
(setq oldrev (strcat (incr_ltr oldrev) "A"))
;; It's rev Z, go to AA
(setq oldrev "AA")
;; The last character isn't Z, all we need to do is
;; increment the last character
(if (> rev_chars 1)
;; It's a two-letter revision, increment the last
;; letter
(setq oldrev (strcat (substr oldrev 1 1)
(incr_ltr (substr oldrev
rev_chars
1
;; It's a one letter revision, just increment it
(setq oldrev (incr_ltr oldrev))
;;it's a number revision, increment it
(setq oldrev (itoa (1+ (atoi oldrev))))
;; The original string is not a valid thing to increment,
;; take our best guess
(setq oldrev "1")
jrf
Member of the Autodesk Discussion Forum Moderator Program
Please do not email questions unless you wish to hire my services
In article <0FB67C05AAD4AAE3A48774FAC7B618EC@in.WebX.maYIadrTaRb>, Kiwi Russ
> In other words:
> then proceed
> E or F G etc
> or "G" or "H" etc
> and
> "H" etc
> etc etc etc
> then show alert box
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 7 of 11
If you plan on incrementing revisions, don't forget that not all sheets are
affect by a revision, so you may even have to skip a revision.
In the case of a Plan Checker he may or may not find an issue on one or more
sheets. There are also client revisions, design revisions, and inhouse
revisions to consider. so you may have a sheet with a revision of 1, 3, 4,
5, 7 etc.
Just my 2 cents.
> In other words:
> then proceed
or
> E or F G etc
> or "G" or "H" etc
> and
or
> "H" etc
> etc etc etc
> then show alert box
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 8 of 11
You can force the input with initget and getkword.
(setq a "A")
(initget (chr (1+ (ascii a))))
(setq b (getkword (strcat "Old Rev.: " a "--Input new Rev.:")))
Ken Alexander
Acad2000
Windows2000 Prof.
"We can't solve problems by using the same kind
of thinking we used when we created them."
--Albert Einstein
revision
letters are
> In other words:
> then proceed
or D or
> E or F G etc
or "F"
> or "G" or "H" etc
> and
or "G" or
> "H" etc
> etc etc etc
> then show alert box
better way
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 9 of 11
You need just one (or ...) clause:
(if
(not
(or ...
(and ... ;;A/B
);;and
(and ... ;;B/C
);;and
(and ... ;;C/D
);;and
);;or
);;not
(alert "Your Message")
(progn
(do stuff)
(do more stuff)
);;progn
);;if
However, there are more efficient ways of doing what you want; see some of
the other replies.
___
> (if
> (not
> (and
> (= RevLettOld "A")
> (= RevLettNew "B")
> );and
> (or
> (and
> (= RevLettOld "B")
> (= RevLettNew "C")
> );and
> );or
> (or
> (and
> (= RevLettOld "C")
> (= RevLettNew "D")
> );and
> );or
> );not
> (progn
> );strcat
> );alert
> );progn
> );if
> thanks Russ
Message 10 of 11
Many thanks!!! everyone.
I have it solved now
cheers Russ
Message 11 of 11
Russ,
And the solution was... ?
Joe Burke
"Kiwi Russ" wrote in message news:f18a035.8@WebX.maYIadrTaRb...
> cheers Russ
Forma Design Contest
AutoCAD Beta
