If it's only after you've been working in the same drawing for some time, it might be a matter of too much Undo information being stored. I have a little pull-down menu item to dump all of that and start over:
[Undo Reset]^C^CUNDO C N;;;
That is, Undo command, Control option, None, then Undo again, accepting the All option default. You can try that manually next time it happens, to see whether it works, before putting it into a menu location somewhere. But of course, you only want to do it when you feel sure you won't want to undo anything back past where you are.
Kent Cooper
sunchase wrote...
....sometimes in the middle of drawing, when I try to select entities using the simple window crossing method it gets real slow both before it selects things inside the window and both after completing the selection.
If I quit the drawing and reopen it, the problem disappears.
Can I solve it without exiting and reopening?
Kent Cooper, AIA
