Visual LISP, AutoLISP and General Customization
program loop to draw lines with rubberband
16 REPLIES 16
Message 1 of 17
1996 Views, 16 Replies
i am writing something that will draw consecutive lines with a rubberband to be used as a leader from a block's insertion point.  this:
(WHILE
 (SETQ LN (GETPOINT "\nSelect Next Point (ENTER to Finish) : "))
 (COMMAND "LINE" (GETVAR "LASTPOINT") LN "")
works, but does not include the rubber band.  i tried:
(WHILE
 (SETQ LP (GETVAR "LASTPOINT"))
 (SETQ LN (GETPOINT LP "\nSelect Next Point (ENTER to Finish) : "))
 (COMMAND "LINE" LP LN "")
which includes the rubberband, but will not exit the loop. The last break source in VLIDE shows that
(GETPOINT LP "\nSelect Next Point (ENTER to Finish) : ") is casuing an error.  Placing
 outside the loop causes all lines to be drawn from the same point rather than the endpoint of the previous line.  any ideas?
16 REPLIES 16
Message 2 of 17
markruys2
try this
(WHILE
Message 3 of 17
in reply to: markruys2
brilliant-- that did it.  thanks.
Message 4 of 17
It looks like it will loop until  (SETQ LP (GETVAR "LASTPOINT")) is not true and I don't think that the "LASTPOINT" variable is set when using the GETxxx functions.
I'm probably missing something here, I don't know what you are trying to do but, maybe you don't need the WHILE. Could you just use ...
 (command "line" (getpoint "LINE Specify first point:"))
That'll keep drawing line segments till you hit enter, has a rubberband, and if you do need the "LASTPOINT" var later, it will have been set.
Message 5 of 17
Is there something wrong with using the grdraw command?
Message 6 of 17
Kent1Cooper
I had the same reaction -- in what way is what the OP is trying to do different from just the basic Line command?  You could forget any routine, and just type L or pick a menu item or toolbar icon or however you normally draw Lines.  But maybe I'm missing something....
Kent Cooper, AIA
Message 7 of 17
in reply to: Kent1Cooper
the purpose was to add this into a program that would place an attributed block, followed by a series of lines - at least one- to be used as a leader.  the first line is inserted in the middle of the tag, then moved to back behind a wipeout.  since mulitple block definitions are saved in the "SYMBOLS" drawing, it was necessary to insert this file to bring in all blocks first.  i could not think of how to run the line command in the normal way and still be able to reset the original variables at the end.  here is the full code:
(defun C:TGL (/ OM CL A B C D SBL LN LP)
(SETQ OM (GETVAR "OSMODE"))
(SETQ CL (GETVAR "CLAYER"))
(SETVAR "CMDECHO" 0)
(SETVAR "OSMODE" 0)
(SETVAR "ATTREQ" 1)
(SETVAR "ATTDIA" 1)
(SETVAR "CLAYER" "NOTES")
(IF (= (TBLSEARCH "BLOCK" "TAG") NIL)
 (PROGN
 (COMMAND "-INSERT" "SYMBOLS.DWG" "0,0" "1" "1" "0")
 (SETQ SBL (SSGET "X" '((2 . "SYMBOLS"))))
 (COMMAND "ERASE" SBL"")
 (COMMAND "-PURGE" "BLOCK" "SYMBOLS" "N")
(COMMAND "-INSERT" "TAG" (GETPOINT "\nSELECT INSERTION POINT :") "1" "1" "0")
(SETQ A (ENTGET (ENTLAST)))
(SETQ B (NTH 0 (CDR (ASSOC 10 A))))
(SETQ C (NTH 1 (CDR (ASSOC 10 A))))
(SETQ D (LIST B C))
(COMMAND "LINE" D (GETPOINT D "\nSpecify First Point of Leader Line :") "")
(COMMAND "DRAWORDER" "LAST" "" "BACK")
(WHILE (SETQ LP (GETVAR "LASTPOINT") LN
 (GETPOINT LP "\nSpecify Next Point of Leader Line (ENTER to Finish) : "))
(SETVAR "OSMODE" OM)
(SETVAR "CLAYER" CL)
(SETVAR "CMDECHO" 1)
(PROMPT "\nFINISHED")
(PRINC)
Message 8 of 17
Ethically, there is nothing wrong with grdraw  Smiley Happy
In fact, just for fun ...
_gile wrote this message on 07-02-2010 02:04 PM in reply to: REID7800
 .../Visual-LISP-AutoLISP-and-General/Grread/td-p/2706707
** BTW How do you link to another thread? Anyone? **
;;replace this
;;(defun grsel (mode fltr / *error* pt ptlst gr loop)
;;with this
(defun c:grline (/ *error* pt ptlst gr loop)
  (defun *error* (msg)
    (or	(= msg "Function cancelled")
	(princ (strcat "\nError: " msg))
    (redraw)
    (princ)
  (setq	pt    (getpoint
		"\nSpecify the first point: "
	ptlst (list pt)
	loop  T
  (princ "\nSpecify the next point or <valid>: ")
  (while (and (setq gr (grread T 12 0)) loop)
    (redraw)
    (grvecs
      (cons -8 (apply 'append (mapcar 'list ptlst (cdr ptlst))))
    (cond
      ((= (car gr) 5) (grdraw (car ptlst) (cadr gr) 8 1))
      ((= (car gr) 3)
       (setq ptlst (cons (cadr gr) ptlst))
      (T (redraw) (setq loop nil))
 ;;replace this
 ;; (ssget mode ptlst fltr)
 ;;with this
  (command "pline")
  (foreach xx ptlst (command xx))
  (command "")
I use this or parts of it all the time.
Change just a few lines (already done here) and it draws very cool rubberband lines and then replaces them with a pline. Just like the OP is trying to do, I think.
Type c:grline
Message 9 of 17
Kent1Cooper
@Anonymous.deleurere wrote:
the purpose was to add this into a program that would place an attributed block, followed by a series of lines - at least one- to be used as a leader.  the first line is inserted in the middle of the tag, then moved to back behind a wipeout.  ....  i could not think of how to run the line command in the normal way and still be able to reset the original variables at the end.  here is the full code:
(SETQ D (LIST B C))
Try replacing the above-quoted portion with:
(command "-INSERT" "TAG" pause "1" "1" "0")
    ; Insert will supply its own insertion-point prompt, and this will set "@"
(setq pt (getpoint (getvar 'lastpoint) "\nSpecify Next Point of Leader Line: "))
(command
  "_.line" "@" pt ""
  "_.draworder" "_last" "" "_back"
  "_.line" pt
); will leave you in Line command
(while (> (getvar 'cmdactive) 0) (command pause))
  ; will keep waiting for further User input as long as Line command is still going
Kent Cooper, AIA
Message 10 of 17
dbroad
michael.deleurere
Might multileader's serve your purpose rather than a program?  You can set up multiple mleader styles.
In your program, wouldn't plines suit your purpose better.  After the initial "PLINE" command, feed subsequent command functions with the points alone.  The leader ends up as one object rather than another.
You could also add a leader object and attach it to your block  That has the leader capabilities built-in.
Architect, Registered NC, VA, SC, & GA.
Message 11 of 17
Kent1Cooper
(command
  "_.line" "@" pt ""
  "_.line" pt
For that matter, you could forget the 'pt' variable, and replace the above with:
(command
  "_.line" "@" (getpoint (getvar 'lastpoint) "\nSpecify Next Point of Leader Line: ") ""
  "_.line" "@"
bobdobbs said "I don't think that the "LASTPOINT" variable is set when using the GETxxx functions," but when one is used inside a (command) function in response to a point-type prompt, that does put the resulting point into the LASTPOINT System Variable.
But I agree with dbroad that a single entity could be better, whether that's a Polyline, Leader or Mleader [(M)Leader Styles can be defined without arrowheads, to be like your Line at the Block insertion point end].  But if you need the first segment to go behind things and subsequent segments not to, maybe you need something different.  Even then, though, you could use a Line for the first segment only, and a Polyline or Leader for the rest -- you could just change the last "_.line" in the above to a different command name.
Kent Cooper, AIA
Message 12 of 17
tthanks for all the good suggestions here-- especially to simplify things as i still have a lot to learn when it comes to autolisp.  i do like the idea of using polylines for the leader, but would like to make the leader optional.
(INITGET 1 "Yes No")
(SETQ LL (GETKWORD "\nINSERT LEADER? Yes or No <Yes>:"))
(IF (NOT LL) (SETQ LL "Yes"))
(IF = LL Yes )
 (PROGN
(command
  "_.Pline" "@"
 ); progn
); if
does not recognize the answer.  how do i translate the YES or NO into the IF statement?
Message 13 of 17
nevermid... missing quotes.  (if = LL "Yes")...
Message 14 of 17
Kent1Cooper
(IF = LL Yes )
 (PROGN
That could be simplified, without the LL variable.  But you don't want that 1 in the (initget) function if you are offering a default value, because that prevents the User from hitting Enter.
(INITGET "Yes No"); without the 1
(if (/= (GETKWORD "\nINSERT LEADER? Yes or No <Yes>:") "No")
  ;; that is, if they type either Y [or Yes] or just Enter to accept Yes as the default [which will return nil]
  (PROGN
Kent Cooper, AIA
Message 15 of 17
dbroad
Again, remember that any block can be used in a mleaderstyle.  Multileaders do not have to have leaders attached.  Using mleader styles could be a very friendly way to work for you.  Dragging each style to a palette gives you access to multiple mleader styles without creating them in each drawing.
Message 16 of 17
in reply to: dbroad
we do use multileaders for notes, but i have not looked into including blocks.  i have had issues with the leader including a landing when the style specifys no landing and the style does not exist in the drawing.
Message 17 of 17
dbroad
Although I don't know your application specifics, I'm pretty sure that using multileaders with your own blocks will be more maintainable and satisfactory than inventing a command to create your own leaders.   If you do keep your method, you might want to group the separate related objects that form part of the leader assembly with a group or to wrap them in an anoymous block.  Moving the leader block and leaving the leader lines behind and the arrow pointing the wrong way increases editing overhead.
I have several of my own commands for creating leaders(with blocks) which I have used for many years and am still impressed by the multi-leader capabilities.  If multileaders had been around when I started, I doubt that I would have coded them.
Palettes work well for storing mleader styles as long as each mleader style has a unique name.
”Boost
