Visual LISP, AutoLISP and General Customization
Nested Block Attribute Values
11 REPLIES 11
Message 1 of 12
1241 Views, 11 Replies
I have a drawing that 'nests' blocks to 4 levels deep.
What I need is a 'list' of the 'tag' and 'value' .. of
each attribute within each level of nested blocks.
I can get the 'first' level..no problem, but I cannot seem
to 'dig' further..to find level 2, 3 or 4 nested block attribute
tagname / value.
Anyone got a Lisp to dig that deep ?
Customer says I cannot 'explode' anything.
Bob
11 REPLIES 11
Message 2 of 12
This gets all attributes in all blockreferences.
[code]
(defun getnestedattributes (doc / atts result)
(vlax-for blk (vla-get-blocks doc)
(vlax-for ent blk
(if (and (vl-string-search "BLOCKREF" (strcase (vla-get-objectname
ent)))
(eq (vla-get-hasattributes ent) :vlax-true)
(progn
(setq atts (vlax-invoke ent 'getattributes))
(foreach att atts
(setq result (cons (cons (vla-get-tagstring att) (vla-get-textstring
att)) result))
result
[/code]
wrote in message news:5265100@discussion.autodesk.com...
tagname / value.
Bob
Message 3 of 12
Maybe this will work. Whooped it up real fast.
(defun c:NestedAttValues (/ Sel Obj)
(defun PrintAttList (BlkObj)
(print
(list
(vla-get-Name Obj)
(mapcar '(lambda (x) (cons (vla-get-TagString x) (vla-get-TextString x)))
(vlax-invoke Obj 'GetAttributes))
(defun GetNestedBlocks (BlkName BlkCol)
(vlax-for Obj (vla-Item BlkCol BlkName)
(if (= (vla-get-ObjectName Obj) "AcDbBlockReference")
(progn
(PrintAttList Obj)
(GetNestedBlocks (vla-get-name Obj) BlkCol)
(setq BlkCol (vla-get-Blocks (vla-get-ActiveDocument
(vlax-get-Acad-Object))))
(if
(and
(setq Sel (entsel "\n Select block to get nested attributes: "))
(setq Obj (vlax-ename->vla-object (car Sel)))
(progn
(PrintAttList Obj)
(GetNestedBlocks (vla-get-Name Obj) BlkCol)
(princ)
Tim
"A blind man lets nothing block his vision."
tagname / value.
Bob
Message 4 of 12
WhooHoo !
Got it now.
Based on Tim's sample..
(defun MakeAttLists (BlkObj)
(if (eq (vla-get-Name BlkObj) "PART COUNTER WITH ITEM AND DESCRIPTION")
(progn
(setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes BlkObj))))
(foreach att atts
(setq att_tag (vla-get-TagString att))
(setq att_val (vla-get-TextString att))
(setq att_lst (cons att_tag att_lst))
(setq val_lst (cons att_val val_lst))
); foreach
); progn
); if
(progn
(MakeAttLists Obj)
(defun C:GO8 ()
(setq att_lst nil)
(setq ss (ssget "X" (list (cons 0 "INSERT"))))
(if ss
(progn
(setq C 0)
(repeat (sslength ss)
(setq blk (ssname ss C))
(setq elist (entget blk))
(setq bn (cdr (assoc 2 elist))); blockname
(setq BlkCol (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object))))
(if
(and
(setq Obj (vlax-ename->vla-object blk))
(progn
(MakeAttLists Obj)
(setq C (+ C 1))
); repeat
); progn
); if
(princ)
); function
Above gets all block inserts, itterates through all
the blocks/inserts/nested blocks.. and picks up
attribute tag / value of 'wanted' block..that has 2
attributes. Lists them all.
Thanks Tim !
I see the 'double' loop in there, that calls the function..
'GetNestedBlocks' .. for each block..
Jeff,
Your example seems to pick up only (top) level, won't find
the nested at level 2 or more.
Bob
Message 5 of 12
Nice one Bob. I'm been practicing my recursive style of programming. This
is one case where it works well. Glad I could help.
Tim
wrote in message news:5265295@discussion.autodesk.com...
WhooHoo !
Got it now.
(progn
BlkObj))))
(foreach att atts
); foreach
); progn
); if
(progn
(MakeAttLists Obj)
(defun C:GO8 ()
(setq att_lst nil)
(if ss
(progn
(setq C 0)
(if
(and
(progn
(MakeAttLists Obj)
(setq C (+ C 1))
); repeat
); progn
); if
(princ)
); function
Thanks Tim !
Jeff,
Bob
Message 6 of 12
Tim,
I gave the user a modified version of the program
that either makes a list of the items found, or shoots
it to a .csv for Excel..and a little routine to add-in a
Bill of Materials. The guy is really happy with it.
Again, I thank you for your 'method' and code,,to
pull out the Attribute values from (any) nested blocks
that may be 'nested' in yet other blocks..etc.
Thanks !!
Bob Shaw
Control Systems & Services, Inc.
http://www.bobscadshop.com
Message 7 of 12
You're welcome Bob. It's nice when you can help someone who has helped so
many others, so I'm glad you were able to give the person something they
wanted, and can use.
Tim
wrote in message news:5266932@discussion.autodesk.com...
Tim,
Thanks !!
Bob Shaw
Message 8 of 12
I should have pointed out one thing Bob. The routine I posted, doesn't look
for constant attributes. I don't know if that is a big deal or not, but it
wouldn't be hard to add it.
Tim
Tim,
Thanks !!
Bob Shaw
Message 9 of 12
Tim,
I'm aware of how to check on constant attributes.
No problems.. have another glass on me !
This particular case.. is flags normal.
Cheers.
Bob
Message 10 of 12
I'm in need of this same type of lisp tool. Could you send me the lisp & CAD file to I can see if it is actually what I need?
Mark
menwiller@cox.net
Message 11 of 12
Mark,
Good to talk with you.
If you need further assist, you know how
to get ahold of me.
Bob
Message 12 of 12
nikm42Q9N
I know this is old but how do you modify the code to find constant attribute values?
”Boost
