Basically I want a dynamic block that works like an MLeader. I have built the block and can manipulate parameters, but haven't found a way to select a specific dynamic block grip.
It has a base point but then after placing the block I want to activate the stretch grip. Has anyone ever tried this?
That's an interesting task you've taken on-
I would like to know the answers too!
And I'll help in getting them if they're still unanswered.
My first inclination is to say that yes it's possible, I even remember reading some forum posts that were mentioning how to make a certain visibility state active and current within a dynamic block reference. I know this is different than activating a grip for stretching but they're both parameters of a dynamic block reference within autocad- see, hardly different!
Anyways, I'll look around theswamp and try to find what I've seen previously, or anything else relevant to accomplishing this task, because I've been wanting to use lisp to mess with these for a while now.
I am trying to develop a new note system for us. I was looking at MLeaders and Dynamic Blocks. I find MLeaders a little clunky and hard to program for because of having to use the DXF codes to manage them. I am really familiar with dynamic blocks, but making them act like an MLeader is a little challenging.
I found this from LeeMac.
http://www.theswamp.org/index.php?topic=43789.0
Its close, but not quite there.
@Anonymous wrote:Basically I want a dynamic block that works like an MLeader. I have built the block and can manipulate parameters, but haven't found a way to select a specific dynamic block grip.
Try this one.
Not sure whether you looking for this (File attached.)
See the image in here.
ajilal.vijayan That is what I want, but now I want to make piont2 hot after inserting the block, to mimic the mleader flow of events when inserted.
That does give me all the dynamic block properties, but not really making them hot. I still think that rubberband for "getpoint", I found at the swamp is the closest thing that I am looking for so far.
You think there is any way to chain the properties so that if the angle of point 2 and the arrow is > than 270 and < 90 degrees it will automatically flip the block?
Yeah you could write a conditional to check the angle and if it's within that range you could have it preform a mirror command on the entity.
I modified the code from swamp and used codes from Lee Mac and Alan JT.
Please find the code in here.
(defun c:test ( / apn dpn dsp ins obj prn ) ;from ;http://forums.augi.com/showthread.php?101772-Add-blocks-to-drawing-without-INSERT-command&p=980191&v... ;; Insert block into drawing ;;; #Name - name of block ;;; #InsPt - insert point ;;; #XScale - block X scale ;;; #YScale - block Y scale ;;; #Rot - block rotation ;;; Alan J. Thompson, 04.21.09 (defun AT:InsertBlock (#Name #InsPt #XScale #YScale #Rot) (if (or (tblsearch "block" #Name) (findfile #Name) ) ;_ or (vla-insertblock ((if (eq (getvar "cvport") 1) vla-get-paperspace vla-get-modelspace ) ;_ if (vla-get-ActiveDocument (vlax-get-acad-object) ) ;_ vla-get-ActiveDocument ) (vlax-3d-point #InsPt) #Name #XScale #YScale #XScale #Rot ) ;_ vla-insert-block ) ;_ if ) ;_ defun ;from ;http://www.lee-mac.com/dynamicblockfunctions.html#toggleflipstate (defun LM:toggleflipstate ( blk ) (vl-some '(lambda ( prp / rtn ) (if (equal '(0 1) (vlax-get prp 'allowedvalues)) (progn (vla-put-value prp (vlax-make-variant (setq rtn (- 1 (vlax-get prp 'value))) vlax-vbinteger)) rtn ) ) ) (vlax-invoke blk 'getdynamicblockproperties) ) ) ;from ;http://www.theswamp.org/index.php?topic=43789.msg490584#msg490584 ;; Polar Stretch Dynamic Parameter Property Names: (setq dpn "Distance1" ;; Distance Name ) (if (and (setq obj (AT:InsertBlock "BLOCKNAME_HERE" (getpoint "\nPick the Block Insertion Point:") 1 1 0)) (= "AcDbBlockReference" (vla-get-objectname obj)) (= :vlax-true (vla-get-isdynamicblock obj)) (setq ins (trans (vlax-get obj 'insertionpoint) 0 1)) (setq dsp (getpoint ins "\nSpecify New Stretch Distance & Angle: ")) (if (and (> 4.71238898 (angle ins dsp))(< 1.57079633 (angle ins dsp))) (LM:toggleflipstate obj) );if ) (foreach prop (vlax-invoke obj 'getdynamicblockproperties) (setq prn (strcase (vla-get-propertyname prop))) (cond ( (= prn (strcase dpn)) (vla-put-value prop (vlax-make-variant (distance ins dsp))) ) ) ) (princ "\nInvalid response or selected object is not a Dynamic Block.") ) (princ) ) (vl-load-com) (princ)
I've almost got it, but it seems to be doing something really wierd to the dynamic block. It doesn't show in the dynamic block definition.
The wierd behavior is because it does not like the leader. If it is made a polyline it will work correctly.
