Solved by paullimapa. Go to Solution.
When you save Views in Model Space and you want to restore them in Paper Space Vports, just use the standard AutoCAD VIEW command.
Inside View Manager window, select the Model Space View name and click Set Current or Double Click on the saved View name and click OK.
AutoCAD will automatically follow the command with a request for you to select a Pspace Vport to restore the View.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
