Hello
with the command _txtscr I can enable or disable the text screen. But I don't know the current state when running a lisp routine. I want to enable the textscreen for more information for the user.
Guido
WIN7, ACAD2014
Solved by hmsilva. Go to Solution.
when you type "textscr" command,it will show the textscreen. for what purpose you want to check the status ?
gschimmi wrote:with the command _txtscr I can enable or disable the text screen. But I don't know the current state when running a lisp routine. I want to enable the textscreen for more information for the user.
Hi Guido,
not quite the answer to your question, but see the graphscr and textscr functions, to display the graphics screen and the text screen from a lisp.
Henrique
Hi Guido,
as already indicated in message #3 with the graphscr and textscr functions, you can control the displays of AutoCAD graphics / text screens, regardless the current screen status if you enter (textscr) you will get the text screen active...
i.e.
(defun c:demo (/ ans) (prompt "\n\n\n Enter a leter: \n\n a for run test_a \n\n b for run test_b \n\n c for run test_c \n\n d for run test_d\n\n") (textscr) (initget "A B C D") (setq ans (getkword "\nEnter an option (A/B/C/D) <exit> : ")) (graphscr) (if ans (alert (strcat "You have chosen to run Test_" ans " program...")) (alert (strcat "You have chosen to exit application...")) ) (princ) )
hope that helps
Henrique
Hello
and thanks for your help...
ACAD made my day!
(type in ACAD textscr and (textscr) and you'll get different behavior)
In my first post I wrote about the usage of '_textscr' (in english versions 'textscr') in lisp (command '_textscr') and that is the flip-flop
And your correct answers where the lisp-function (textscr)...but I needed the week end to understand this
Guido
