Link multiple functions/routines?
7 REPLIES 7
Message 1 of 8
300 Views, 7 Replies
I have written 8 individual routines/functions in 8 different .lsp files. Now, I would like to write a routine that calls the sequential execution of each routine one after another.This will mean simplification on the user part as user only have to run one file to get all 8 routines/functions running. How do I do that? Any ideas anyone?
Rgds,
Melissa
7 REPLIES 7
Message 2 of 8
Assuming they are all loaded you could add the function call at the end of
each lisp.
For example....
(defun C:Lisp1 ()
.... program here ....
) ; end of lisp
(defun C:Lisp2 ()
) ; end of lisp
Do this .....
(defun C:Lisp1 ()
(C:Lisp2)
) ; end of lisp
(defun C:Lisp2 ()
(C:Lisp3)
) ; end of lisp
You could modify the eight different lisp progams to be eight functions of
the same file and so on ...
For the best answers, zip up the coding and post them to the customer files
area so we can see them....
Customer Files is an area for upload of problem files for review or sharing.
Users are asked to zip any files prior to uploading to conserve download
time and server space.
For NNTP newsgroup readers the Customer-files newsgroup can be found at
news://discussion.autodesk.com/autodesk.autocad.customer-files.
Chip Harper
Member of the AutoDesk Discussion Forum Moderator Program
Message 3 of 8
oops, forgot the http link ...
You may also access the customer-files group via the HTTP web-based forums
at http://discussion.autodesk.com/WebX?14@@.ee940b5.
Chip Harper
Message 4 of 8
Hi I have tried this, this case i tried to link 2 routines to run within a single file:
(defun c:auto_dim()
(defun c:longest())
(defun c:cornerwires())
However, after I load in auto_dim, at the autocad command prompt, i still need to type longest & cornerwires to run the individual routines..Is there a way to run both routines with a single command, like after i type auto_dim?
Rgds,
Melissa
Message 5 of 8
I tried ur 2nd suggestion..it works..thanks 🙂
Rgds,
Melissa
Message 6 of 8
Welcome 🙂
Chip Harper
Message 7 of 8
Melissa,
Unless you always need the 8 different functions to
operate as
one, then a ninth function that executes the others
would perhaps
be a better choice.  In a ninth
file:
(defun c:cmd9()
   (c:cmd1)
   (c:cmd2)
   (c:cmd8)
(princ))
(load "fileofcmd1")
(load "fileofcmd2")
(load "fileof cmd8")
(princ "all files loaded")(princ)
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Rgds,
Melissa
Message 8 of 8
I am having this same issue and this link doesn't work. What was the solution to this problem?
”Boost
