Showing results forĀ
Did you mean:Ā
integer into binary
5 REPLIES 5
334 Views, 5 Replies
integer into binary
i searched my acad 2000 documentation to find a function which converts
an integer into a binary, but i couldnĀ“t find... is there one, or do i
have to program it by my own?
mfg
gert
5 REPLIES 5
There isn't a native one, you would have to program your own.
Kevin Nehls
"DI Klaus Umlauf" wrote in message
news:3D4FDEC2.273DEC86@utanet.at...
> mfg
> gert
I don;t think there is 1 included.
This is a very old 1 I wrote long ago. Returns STR value
;;;Convert Integer To Bit String - 1s & 0s
;;;ARG -> INT to convert
;;; INT of length to return
(defun ItoB (int bitlen / mod power rpt) ;Define Int To Bit
(setq retbit "" ;Reset Bit String
power (abs 0) ;Reset Power
mod int) ;Set Divisor To Input
(while (>= mod 1) ;While The Remainder Of
(setq mod (/ mod 2)) ;Division Of The Remainder
(setq power (1+ power))) ;By 2 Is Greater Than 1
(setq rpt power) ;Increase The Power By 1
(repeat rpt ;Repeat Power Times
(if (>= int (expt 2 (1- power))) ;If The Integer
(progn ;> 2 To The Power -1
(setq retbit (strcat retbit "1")) ;Set The Bit To 1 Then
(setq int (- int (expt 2 (1- power))))) ;Decrease By 1 Power
(setq retbit (strcat retbit "0"))) ;Else Set The Bit To 0
(setq power (1- power))) ;Decrease The Power By 1
(while (< (strlen retbit) bitlen) ;Add 0's To Match BitLen
(setq retbit (strcat "0" retbit))) ;Returns The String
(setq retbit retbit)) ;And End
"DI Klaus Umlauf" wrote in message news:3D4FDEC2.273DEC86@utanet.at...
> mfg
> gert
thank you a lot, you saved me hours...
mfg
gert
> > mfg
> > gert
just curious, what is the application for this? ie in what situation do you
need the binary representation of an integer?
quick method to check if eg. endpoint is set in sysvar "OSMODE"....
ā€Boost
