Visual LISP, AutoLISP and General Customization
Explode all in a script file
2 REPLIES 2
442 Views, 2 Replies
I can type explode all at the command line and it does just that.
When I try it in a script, I get "Expects a point or
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle.....
Any help appreciated.
2 REPLIES 2
Explode All requires that the objects that you want to explode must be visible on the screen. Try doing a Zoom Extents prior to calling the explode in the script. That might work. Also, make sure that the objects you want to explode are not in any frozen, off or locked layers. Hoep this helps. Rgeards Rakesh peterthomson wrote: > I can type explode all at the command line and it does just that. > When I try it in a script, I get "Expects a point or > Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P > revious/Undo/AUto/SIngle..... > Any help appreciated. -- AutoCAD customization for Engineering/Mapping/GIS Get GeoTools @ http://www.4d-technologies.com/geotools Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm FREE downloads : http://www.4d-technologies.com/techcenter
Explode in script works like in lisp (command "_.explode" ...) form try: (setvar "QAFLAGS" 1) (command "_.explode" (ssget "_X") "") (setvar "QAFLAGS" 0) -- ________________________________________________ Marc'Antonio Alessi (TV) Italy (strcat "NOT a " (substr (ver) 8 4) " guru.") O.S. = XP Pro 2002 Ita - Sp.1 AutoCAD = 2004 Ita - Sp.1a ________________________________________________
Autodesk Customer Advisory Groups
