Visual LISP, AutoLISP and General Customization
Default value : incorrect choice
9 REPLIES 9
Message 1 of 10
YvesLEHURT8573
385 Views, 9 Replies
Bonjour,
I have this code (see below) and use the (saisie dynamique) "dynamic input"
Dynprompt = 1
Dynmode = 3
  (initget 1 "A S")
  (setq ch_vasp (getkword "\nVanne : [Avec/Sans (cas std)]<Sans (cas std)> ? "))
With AutoCAD 2009 I can validate the default value with "Enter"
With AutoCAD 2012 I can't !
I get (Choix de l'option incorrect) Option choice Incorrect
Any idea ?
Thanks in advance.
Yves
9 REPLIES 9
Message 2 of 10
pbejse
in reply to: YvesLEHURT8573
initget 1 prevents the user from responding to the request by entering only ENTER.
Not sure how you were able to suppress that with 2009, but you shouldnt be able to
Message 3 of 10
YvesLEHURT8573
in reply to: pbejse
Your argument is correct without dynamic input.
With dynamic input on AutoCAD 2009, I can valide the default value.
Why not with AutoCAD 2012 ?
Is there one new sytem variable to manage this ?
Yves
Message 4 of 10
pbejse
Guess you're right. right now i'm using 2004 version  my 09 cad  bogged down last night. cant test on 2009 much more 2012.
I cant be of any help on that for now YVES  🙂
 in any case, did you try removing 1 from your initrget statement?
Message 5 of 10
YvesLEHURT8573
in reply to: pbejse
If I remove 1 to iniget and if the value of Dynprompt is 0
and validate the question by return
I obtain nil in the variable.
So I can't accept this solution.
Sorry.
Message 6 of 10
pbejse
If you DO remove initget 1
you would need to add to your condition statement
(cond
      ((null ch_vasp)(do this))
      ((eq "A" ch_vasp)(do this))
      ((eq "S" ch_vasp)(do this))
and its a suggestion not necesarily a solution.
or this
(initget "A S")
(if (not ch_vasp) (setq ch_vasp "A")
Asfor the new sytem variable and why it wont work in 2012. my anser IDK.
Hope this helps anyway Yves
Message 7 of 10
YvesLEHURT8573
in reply to: pbejse
My question is "why it doesn't work on AutoCAD 2012 and works on AutoCAD 2009 ?"
Yves
Message 8 of 10
I understand and know your solution but ... it's not my choice for this problem.
Sorry
Message 9 of 10
pbejse
Sorry
No worries Yves. i would want to know the anser to that question myself even before i start usign 2012
Keep us posted if you find the answer
Message 10 of 10
Lee_Mac
This tutorial may be of some help. Smiley Wink
Autodesk Customer Advisory Groups
